chisel plow leveling bar
ih886/1066
my landoll disc chisels leave the telltale furrow ridges and was thinking about something like unverferth spike tooth bar behind like behind my perfecta
finisher. trying to skip a pass later on. once with disc/packer then with perfectas. only 5 shank.would need like 7 footer.whatya think? wonder about cost and where to buy. sw pa. very few dealers. thanks
I’ve seen a simple buster bar like a moldboard plow uses, and I’ve seen a bar with a few cultivator shanks to knock the ridges off. If you are fall tilling I would think either of these would combine with winter mellowing to make a spring one pass easy. I would only use a harrow if spring tilling.
Look up The Ridge leveler, by Pepin
I have a couple sunflower chisel plows and the both have flexible spike harrows on them.  Really helps smooth things up in the fall and I can make 1 pass in the spring and plant with no trouble.
