TM 125 hydraulic issue
Was over helping FIL switch the hydraulic filters under the rhs of the cab on his TM as the warning light was on. Light is still flashing after the filter change. All the hydraulics, loader, 3pth function normally. Found somewhere about recalibrating the transmission, or possibly a bad sensor. Just wondering if anyone has any insight into this issue as I haven’t worked on one of these yet.
Made it over to check it out this evening. Pretty sure we found a short in the short jumper harness from the main harness to the sensors. Will see how soon we can get a new one. Pulled the vacuum switch and tested with mechanical gauge. Wasn’t enough to close the vacuum switch. Thanks for the help!
