peanut Posted January 24 Share Posted January 24 Trying to add a second remote , are 966, 1066 hydraulic scv valves interchangeable with 856? Can't find an 856. Quote Link to comment Share on other sites More sharing options...
560DT Posted January 24 Share Posted January 24 yes they will work Quote Link to comment Share on other sites More sharing options...
snoshoe Posted January 24 Share Posted January 24 06-56 had a larger unlatching piston for the lower pressure. 66 series had just a straight pin for unlatching. They work for each other. Just need to adjust to the pressure used and be aware when getting parts to reseal. 1 Quote Link to comment Share on other sites More sharing options...
Matt Kirsch Posted January 24 Share Posted January 24 Does not need to be specifically for an 856. Could be for a 7-8-1206, a 7-8-12-1456, 8-1026, if you feel having matching valves is important. All the 7-9-10-14-1566 will also work, but as mentioned the latching piston is smaller. Not a big deal just take the parts with you to match up at the dealer if it needs a rebuild. Quote Link to comment Share on other sites More sharing options...
peanut Posted January 29 Author Share Posted January 29 Found a junk 1066, super great guy gave me both valves and all brackets and handles. Should I use both valves off 1066? Anyone know oring sizes between valves? Don't have a dealer within a 100 miles. Quote Link to comment Share on other sites More sharing options...
766 Man Posted January 29 Share Posted January 29 4 hours ago, peanut said: Found a junk 1066, super great guy gave me both valves and all brackets and handles. Should I use both valves off 1066? Anyone know oring sizes between valves? Don't have a dealer within a 100 miles. May I ask what the cost was? Quote Link to comment Share on other sites More sharing options...
peanut Posted January 29 Author Share Posted January 29 Free Quote Link to comment Share on other sites More sharing options...
rrr4quality Posted January 29 Share Posted January 29 Does he have a left cab door also?😉 Quote Link to comment Share on other sites More sharing options...
stronger800 Posted January 30 Share Posted January 30 Good find. That would be $800-900 around here. Easy. Quote Link to comment Share on other sites More sharing options...
Matt Kirsch Posted January 30 Share Posted January 30 23 hours ago, peanut said: Found a junk 1066, super great guy gave me both valves and all brackets and handles. Should I use both valves off 1066? Anyone know oring sizes between valves? Don't have a dealer within a 100 miles. I would. Keeps the parts consistent. 1 Quote Link to comment Share on other sites More sharing options...
Missouri Mule Posted January 31 Share Posted January 31 Wow. That would be over a grand around here. That "middle" valve alone is normally 500 used. You got lucky. Quote Link to comment Share on other sites More sharing options...
