What ya working on?
billonthefarm
29 minutes ago, Dirt_Floor_Poor said:
I took this Timken bearing out of a combine today. I put it in maybe three years ago. It was made in Turkey and is apparently junk like everything else you can buy now. I took the original bearing out of this machine that lasted 15 years. Now they last two or three. They are nothing more than an expensive, low quality fire hazard.
That's disappointing. Timken used to be good bearings
I still see some that come with made in USA on them. Maybe they are still good. I also get some Timken that say made in China in addition to the ones from Turkey. I have actually had decent luck with the Timken bearings that are Chinese.
Well you remember the root rake I installed a couple of weeks ago. I got a call Monday, we got a problem with the root rake.
Pic #2&3 is what greeted me Tuesday morning when I showed up. So I broke out the torch and air arc. 90% of the welds I gouged out were full of porosity, One tooth had broke off and they found it, it only had about 2" of weld holding the rest were cold lapped.
Pic #4 is where I am at now.
When you want something done right, do it yourself!!
Make it cheap and sell it expensive. Just get it out the door and then have the customer totally rework it after almost no use. Typical.
That looks better. I think you could tear the original version up with a D3 never mind a D6.
Finished this morning, good thing I think I am coming down with sinus infection. About the time I got back to the shop they called and said we have broke/cracked the C frame and ball mount. I said good luck it will be at least Monday before I come back.
  • Like 7
Take care of yourself Finney!
That looks like a power 6 way? I still say that's way to big of a machine for that setup, you would need a tightwad owner operator with a brain to stand any chance of not turning it into spaghetti before the new year
On 12/8/2023 at 11:45 PM, Alan Dinan said:
Had the neighbor over here with a trackhoe to dig out some trees that were too big for the backhoe. Hauled off a few loads of concrete too.
Oooooh eye candy love diggin in the dirt!!!
Probably be better off with a rear ripper
One new shoe for the 560 tonight.
Different seat tho I didn't realize I need a couple of spacers to go under it. Luckily I have a parts breakdown that confirmed what I suspected after mounting the seat tonight. Lil bit of side to side slip so I will need to dig into that....
 Middle Pic of the seat someone had put on it. If the one I jist bought doesn't work out it may go back on. 🙄
  • Like 9
Worked on a barn roof and a buddy of mine put some lights up for us. The man lift makes both those things a LOT easier.  Well worth paying him to bring the lift over.
  • Like 9
Timken has been on a huge buying spree of anything driveline related.  Bearing, seal, coupler, whatever.  Makes me think that quality from them is now suspect.  If I want good conical bearings I ask for NTN/Bower.
But all companies are able to send out junk.  Had an SKF 208 size self aligning 40mm bearing go out this fall on a one year old machine.  Really??  I do think the seals on that particular bearing # is junk though, not my first rodeo with them.
It is, too much power for a 6 way. Another contractor has 2 of them also, has put close to 6,000 hrs with none of these problems.
How biga sledge hammer u use to pound it in?
  • Haha 4
11 hours ago, Rawleigh99 said:
It all comes down to the operator. What's the number of good operators declining though you want something that's pretty bulletproof.
I think most people thing a murray riding mower is a brush cutter now days and wonder y they tore it up
Or have @Finney do it for you
