What ya working on?
billonthefarm
thanks, The tires were taken off a showroom/trailer queen resto on a Massey and the guy gave me a terrific deal on them, I put Michelin tubes in them so I think its good for a longtime, Longer than I will be above the lawn
I figure if they are done right they have a smaller chance of getting scrapped in the future
Putting a new hitch h on a disk bine. This is the one that goes on the front of the tractor. The latch failed on the quick hitch and destoryed the quick hitch on the tractor and the hitch on the disc bine.
  • Like 8
806 week,well kind of ,if not doing little things that need done ,it's work on the 806 with hand clutch, It's always a puzzle how perfectly good wore out bare and semi melted wires can grow 5 lbs of tape ,extra wire that dead ends and useless connectors .🤨
That's like seeing electrical tape in a random place on a wire, unwrapping it and finding a simple wires twisted together connection. Then, noticing a bunch of other random pieces of tape...........
Just put a head gasket and a bunch of other stuff in my commuter car I drive to work. Not a fun job, but hopefully it will be in good shape for a while now. FYI, I think I've discovered that 150,000 miles is about the expected life of a headgasket on a Ford Fiesta...and maybe the expected life of the whole car!
This one has 152,xxx. You see a bunch for sale with around 150,000...
hmmm...
I ready to get back to wrenchin on farm stuff.
  • Like 6
hmmm...
That looks like it probably took a while. That stuff is never easy to get to unfortunately.
The 2013 Nissan with 30,000 miles on it has decided to occasionally not indicate speed.  Probably more rodent damage, now I have an excuse for speeding, "But officer my speedometer says I was stopped".  I need to determine if the odometer is counting if the speed indicator is at 0. Tranny shifts fine and it starts and runs fine. Probably a victim of Texas heat wave.
Yeah, took a while. I had basically everything off the engine except the transmission and the AC compressor.  My mechanic didn't want to tackle it in case he got the head off and we found out the engine was toast, then he would have a bunch of labor in it, etc. ... So I had no choice but to do it. Not the hardest thing I've ever done, but I'd rather not do it again any time soon!
Hydraulic log cut off saw. It broke the bolts off holding the bar to the swivel plate. Had to remove the swivel plate to get the bolts out. 3/4'x3", four of them. Got them out and replaced with grade 8 day before yesterday and torqued to 280lbs. Decided to recheck the torque yesterday and all of them turned over a 1/4 of a round to achieve 280lbs. Went to Cat this morning and got grade 10.8 and torqued to 340lbs.
The cutter bar on this is over 5ft. long and heavy. i believe they are cycling it too fast.
  • Like 6
Loggers pushing their equipment a bit too hard?! Never!
  • Haha 3
Putting some new headers on this ‘Cuda, think it’s a 1972, has a 340 and 727, not perfect but a really nice car, underside is awesome
The job before this ‘Cuda was repairing a rear differential mount in a 2004 RAV4 that is very rotten, a car that I would typically say is not worth fixing but it just needs to last another couple weeks until I have the Honda Odyssey ready that they bought this weekend to replace the RAV4, the Odyssey is supposed to be here sometime this week.
Was working on a 2014 Ram 1500 first thing today.  It came here with complaints of noises and vibrations.  The front differential output shafts were rusted and splines depleted, CV shafts falling off.  Only way to get the output shafts are with a complete differential from Mopar, about $3000.  I found some aftermarket shafts on Amazon that are made by a Canadian company with CV axles for about $1000, put them in a while back and I’ve been chasing a terrible driveline vibration in it since.  In my efforts to isolate the vibration I found the transfer case clutch(auto 4x4) was slipping, found this while driving it with the front driveshaft only.  It would not positively drive and when it engaged it would shudder/vibrate bad.  I put a new used transfer case in it today and it vibrates less but still too much.  I put a new transmission mount in as well because it was delaminated, motor mounts look ok, a couple u joints are a little sticky but with my efforts to isolate the problem by running the front and/or rear driveshaft only the u joints aren’t the biggest problem.  I had only the front driveshaft installed and decided to get my daughter to hold the brakes and load it up while in gear while I watch the motor mounts.  She was nervous about running me over, proud of her for thinking about that, but I assured her that I would watching from the side, not in front.  While we were doing this operation a loud bang happened and there was no drive, the passenger side front differential output shaft sheared off.  I was starting to wonder if the new CV axles are the cause of the vibration but was reluctant to take them out because of the work involved but I think that’s my next step now, if I have to contact the company for warranty on the output shaft I may as well prove that I don’t need axles too.
I figured this ‘Cuda was exceptional enough to share, and then thought sharing my other jobs of the day would be a good example of the variety of work I get in to.
  • Like 6
Changed the oil last night in my 99 with the 7.3.
Also finally got around to changing the brake light switch that has partially failed and as a result cruise, lock up convertor and shifter interlock would not work. I was dreading it, so put it off. Think I was recalling a switch that was a lot worse and was half scared not all my problems were related to the switch. Turned out it was very easy and it did indeed take care of the mentioned issues.
  • Like 8
I always liked the single cabs of those models 👍🏼👍🏼
11 hours ago, jworley said:
I’m in the process of getting this thing back road ready. Not a tractor but, it does have an IH engine.
28 minutes ago, new guy said:
Good lighting, concrete and less crawling on the ground. Still working on it.
Good to see you new guy. I take your new shop is a go!
I have a similar problem, that’s the next thing on a very long list. I’m working on running down a fuel leak at the moment.
4 hours ago, Gearclash said:
First real job for the boring mill. Cutting out bad shaft bosses etc. Kind of a tall drink of water.
I love your awesome quansit n wood ceiling - nice job on the machine work side hustle!!!
