Posted
Straighten fender out . It takes me awhile cause it’s cold in the garage .
Time is not an object. Just make it right .
I don’t use hammers and dolly’s cause it just creates more work. Only use industrial cheat gun to warm the metal . Learned my lesson on Fordson Fenders.
I cut out templates of the good fender and use c clamps to return metal to it original shape, it has memory , just I have to find it, and put it back there .
  • Like 8
Posted
On 1/23/2023 at 10:53 AM, lorenzo said:
Just finished this old Y-Block.
managed to squeeze 400 HP out of it
This picture just popped up on my screen, I don't know why.
I just Helicoiled the water outlet holes for my FIL. He's got a very original '56 Victoria with a 312 and the original teapot 4 barrel and has this with 97s he may install.
  • Like 6
Posted
52 lbs sausage
27 qts of ham
plus the tenderloins, ribs, and such
One more hog to do, but not for a day or two, I hope!
  • Like 11
Posted
22 hours ago, TN Hillbilly said:
52 lbs sausage
27 qts of ham
Nice! That canned meat looks awesome.
Posted
3 hours ago, Phelpst said:
Brought 4 more in the weekendIMG_3531.thumb.jpeg.95d2be5d2f0e1562cbfcb7fc133f0841.jpegIMG_3541.thumb.jpeg.39799116937794a73974348b503be59d.jpegIMG_3544.thumb.jpeg.f64f9117970335db19c4c0cb503dd68a.jpegIMG_3533.thumb.jpeg.cb33281a29579a3fe10f235c13ac63ed.jpeg
2 Ms, an SMTA and an H? Looks like they didn't like hoods on their tractors!
Posted
We only found one hood in the barn and luckily a super straight grill
Posted
The Super MTA hood is one of its own.
Posted
The old  gal is back from the dead, parts were pretty hard to find. Thanks to a man in Australia and two different places in the States i was finally able to obtain the parts i needed.  1968 090AV
  • Like 7
Posted
Nice saw!
Posted
Forklift repairs seems to be a regular thing at the moment just made 2 of the most expensive upper side shift bearings on the planet as could not find anything on the market with the right dimensions old and obsolete all done now and time to get a well deserved beer I thinkIMG_0960.thumb.jpeg.ceba2bbcde302cbb7114dd8d0366ac88.jpegIMG_0963.thumb.jpeg.38fc0c71afadd046d60d4ca17c32392d.jpegIMG_0964.thumb.jpeg.010bc6d3a26069d48b812b57f97348e9.jpeg
  • Like 12
Posted
Swapped a crankshaft in a N14 Cummins for my concrete buddy. His guys pulled the engine and pan, front cover , bell housing. I swapped rod, main bearings in and crankshaft for him. I rolled in main and rods last year for him I frame but the thrust area on crank was really bad so he wanted to swap crank. They found the thrust bearings in oil plug hole during oil change.
after that I started pulling down a 05 or 06 ism Cummins with egr in a mixer truck. This one he bought used out of Sioux Falls sd area last year but it burns oil. I have the engine apart now and suprising it is pretty good shape inside. So going to just throw a aftermarket kit into it and reuse the head.
  • Like 9
Posted
Replaced the fuel bowl drain valve on the 99 f350 yesterday. That leak is fixed but still getting a drip from somewhere. Hopefully just fuel that pooled in the valley of the 7.3 when I pulled the drain valve. Looked quite a while with it running and not running. Can't for the life of me see any other leaks. Hopefully it will dry up.
  • Like 6
Posted
On 2/7/2026 at 8:06 PM, lorenzo said:
Black Walnut trees.
Three more to go, cant even give it away here.
Local mill would buy that size walnut logs, anything bigger than 10". Nobody buyin around you?
Posted
Theres a real nice lumber mill just a few miles from me, i have offered them walnut twice. Unless its at least 18” in diameter they dont even want it for free.
Posted
Had to replace the rear fuel tank strap on a 2002 F250 Super Duty, when I got into it I found the crossmember for the front strap needed attention.
IMG_4694.thumb.jpeg.5543ddff660f99c2e321c85ae3c21108.jpegIMG_4668.thumb.jpeg.5be2c3bbbd7d6b32faebb31f840d4dc3.jpegIMG_4677.thumb.jpeg.43876d5b8f31af36a9ba4924b52fb539.jpegIMG_4680.thumb.jpeg.45039513cb065b66d57272661e1a4cb3.jpegIMG_4683.thumb.jpeg.e95de0843ffab3dfa5b907023a4841e0.jpegIMG_4684.thumb.jpeg.a685d0ceb8a4c9367d6769f51e2e38ff.jpegIMG_4687.thumb.jpeg.bd3df615e142bc0f3d55fe3cd205afe0.jpeg
  • Like 11
  • Sad 1
Posted
Putting another engine in my gator.  When I got it 15 years or so ago, it had been overheated so bad that all the plastic cowling had melted onto the block. Governor gear inside also melted.  I put it back together enough to run, figuring I would replace it when it blew up. It never did, but is getting hard enough to start to be annoying and leaking antifreeze almost as fast as I could pour it in. So, I fixed the locked up engine I had bought as a replacement years ago and put it in. Guy had supposedly rebuilt it, but used silicone for a pan gasket leaving the crank no end play and partially blocking the main oil passage. It didn't run long enough to do much damage.
  • Like 7
Posted
We were working on this 2001 Chev 3500 this week.  It’s a pretty decent truck, has the 8.1L.
It had one broken wheel stud starting out and broke another 4 studs coming apart.  It needed a front wheel bearing replaced, the bolts were seized right in there and the hex was depleted.  I heated the flange where the threads are and still stuck, blew most of the female side of the thread away except for a 1/16-1/8 at the seam of the bearing and spindle and still didn’t come, blew the last bit off and then it went.
We installed some new 285/75R16s, it’s a good look.
IMG_4692.thumb.jpeg.5b1eda94a6ddf7d3cd558f3214ce1fc1.jpegIMG_4691.thumb.jpeg.4780b2ceada1212a235ff6fea0f461ab.jpegIMG_4701.thumb.jpeg.ebd689013f0c6f79a0d2186a8e39b825.jpegIMG_4700.thumb.jpeg.53e2f34a47bc0a737115923621f20573.jpeg
  • Like 12
Posted
Been there.  It’s near impossible to clean up that valley enough to find any possible minor leaks or seepage.
Posted
Very nice work!I worked on Hysters with either rightline or cascade attachments which had similar bearings.They would last a long time if kept lubed.Most people don't know their even there.
Posted
yep
Posted
Worked on the roof of my corn crib today, hopefully good for another 5 years os so now.... Buddy Dan was over, we worked on some trees too. One loader bucket of walnut firewood and three of brush. My view is improved an immeasurable amount. Good times!
