5488 mfwd front hub?
2+2love
On a 5488 mfwd
Is number 31 in the diagram the only thing that prevents the sun shaft from hitting the bearing retaining bolts?
I'm putting it back together and something doesn't look right. But I think I'm putting it back together just as the parts book shows.
I installed new bearings, seals and set the bearing preload.
The book is the exact drawing of the original setup so it should be correct . The Magnum has the same setup and there service manuals are very good , if you want I can look it up and post a picture .
Danny
It's all back together I have everything just the way the parts book shows.
The best thing is the other side is not showing any sings of wear. So it was only one side that needed repair.
Thank you to everyone that has helped me.
