frmboy52 Posted December 28, 2022 Share Posted December 28, 2022 new to the forum but here goes... got a 1086 with PFC system .. the position lever will not raise the 3 point unless the draft lever is all way back ...remotes ( all 3 ) function properly and strong . not new to Internationals but new to this problem .. and too the tractor had been sitting a while before purchase. if anybody has any thoughts on the issue it would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
snoshoe Posted December 28, 2022 Share Posted December 28, 2022 The hydraulics seem to be working so hook up or adjust position linkage. Quote Link to comment Share on other sites More sharing options...
mrfred54 Posted December 28, 2022 Share Posted December 28, 2022 With the draft lever all the way back, the hitch should be up all the way anyhow. With the draft all the way up, and you lower the Position controlĀ the hitch should remain up. Sounds like position control linkage has slipped out of adjustment Quote Link to comment Share on other sites More sharing options...
mrfred54 Posted December 28, 2022 Share Posted December 28, 2022 Oh, by the way, Welcome aboard Quote Link to comment Share on other sites More sharing options...
frmboy52 Posted December 28, 2022 Author Share Posted December 28, 2022 thanks for the welcome.......have already checked behind the top link hitch and all is in order....can lower the draft control down about a quarter of the way and control lever lifts three point and lowers it in the back 2 to 3 inches of the slot...and by the way the serial number for this tractor is 261018Ā 3U52281 andĀ I cannot find that SN anywhere to distinguish the year model Quote Link to comment Share on other sites More sharing options...
hippy5488 Posted December 28, 2022 Share Posted December 28, 2022 adjust linkage. under right side of cab. if been setting for a long time friction adjustment might be hanging up causing the flimsy linkage between bottom of lever and control to flex Quote Link to comment Share on other sites More sharing options...
ksfarmdude Posted December 28, 2022 Share Posted December 28, 2022 36 minutes ago, frmboy52 said: thanks for the welcome.......have already checked behind the top link hitch and all is in order....can lower the draft control down about a quarter of the way and control lever lifts three point and lowers it in the back 2 to 3 inches of the slot...and by the way the serial number for this tractor is 261018Ā 3U52281 andĀ I cannot find that SN anywhere to distinguish the year model Looks like '81 yrĀ last year for 86 series Quote Link to comment Share on other sites More sharing options...
frmboy52 Posted December 28, 2022 Author Share Posted December 28, 2022 thanks for the input ......... willĀ check out the linkage tomorrow..........Ā Ā and thanks for th SN info Quote Link to comment Share on other sites More sharing options...
frmboy52 Posted January 4 Author Share Posted January 4 linkage all checked out good ....just pulled a 14 ft Hutchmaster offset plow over 32 acres and everything functions as it should except the 3 point ......i'm kinda at a loss as to where to go from here Quote Link to comment Share on other sites More sharing options...
snoshoe Posted January 4 Share Posted January 4 1 hour ago, frmboy52 said: linkage all checked out good ....just pulled a 14 ft Hutchmaster offset plow over 32 acres and everything functions as it should except the 3 point ......i'm kinda at a loss as to where to go from here Hard to believe. Seems it has to be linkage. So back to the top. With position control forward. Pull draft lever back. When in the vicinity of 2 inches from the rear of quadrant.Ā The hitch should start to rise and won't stop until at top or lever is moved forward. When lever is moved forward. Hitch starts to drop and doesn't stop until down. Is this what happens? If not fix this first. If yes. You have a problem with position linkage. It's not all on the outside. Quote Link to comment Share on other sites More sharing options...
frmboy52 Posted January 4 Author Share Posted January 4 yep , that is just about what happens ... except that the position control lever somewhat raises and lowersĀ , ( not as correctly as I would think comparing it to my other tractors )... while the draft control is in the back 2 to 2 1/2 inches of the slot... I'll dig a little deeper on the position control ... Thanks Quote Link to comment Share on other sites More sharing options...
snoshoe Posted January 4 Share Posted January 4 15 minutes ago, frmboy52 said: yep , that is just about what happens ... except that the position control lever somewhat raises and lowersĀ , ( not as correctly as I would think comparing it to my other tractors )... while the draft control is in the back 2 to 2 1/2 inches of the slot... I'll dig a little deeper on the position control ... Thanks Well I guess I am the one confused. Draft should not be in rear 2 to 2 and1/2" Quote Link to comment Share on other sites More sharing options...
frmboy52 Posted January 5 Author Share Posted January 5 LOL - so am I , controls are unlike my 1466 and 856 but if I poll the draft control all way back it lifts the 3 point with or without an attachment . i can lower it down to a point 2 to 2 1/2 inches and to relieve the pump strain the control leaver will do the same in the very back of slot , if I move the draft lever any futher towards heavy draft , neither will perform until I take the draft all way back and start the process again . drawing blanks about the issue .Ā at 70 I got a lotta projects to get rid of but didn't want this to be one of em Quote Link to comment Share on other sites More sharing options...
snoshoe Posted January 5 Share Posted January 5 Picture I am getting is that position control does nothing unless draft is back. Then does nothing until all the way back and then either raises on drops with no position control. Indicates failure of feed back from rockshaft. That linkage is inside. Quote Link to comment Share on other sites More sharing options...
frmboy52 Posted January 5 Author Share Posted January 5 thanksĀ snoshoe.......... under top cover or accessable thru the top link hitch portal ?.......and what mite I be looking for ? my IT manual goes nowhere in this area Quote Link to comment Share on other sites More sharing options...
snoshoe Posted January 5 Share Posted January 5 It's all inside top cover. It's certainly worth a look in that rear hole. Rather limited to what you can do there. Look for anything broke or disconnected between rockshaft and control valve. It gets kind of complicated as the follow up, position control and draft control all operate the same spool. Quote Link to comment Share on other sites More sharing options...
frmboy52 Posted January 5 Author Share Posted January 5 thanks ..... will take another look from the back before I take the top off Quote Link to comment Share on other sites More sharing options...
