5288 Pto runs when the tractor does and PTO is off
Clark Riley
Can you turn the Pto by hand with tractor off??    If not I would say the discs are melted together and the hyd brake pads burnt.   So you would have to drain oil and pull Pto out of the rear to rebuild.   Or that tractor would look good on our farm if you wanted to get rid of the problem!
1 hour ago, Takn4aFool said:
looks like 10 from here
4 hours ago, IHC5488 said:
How many bottom is the 800?
I'm assuming that it's a 855 big cam swap by the exhaust system...
Most likely you will need to remove the PTO unit and overhaul it with new clutches and seals. Either drain the hydraulic oil or park the tractor on a steep downhill before pulling the PTO or you will have a mess. I failed to warn someone about that once and they were not happy when they were standing ankle-deep in hydraulic oil.
If a person has to bad told they need to drain the oil, I think they are in Way over their head..
