Tom560 Posted November 22, 2022 Share Posted November 22, 2022 Hello, Is the Dt 361 engine used in the Farmall 1206 the same as the Dt 361 engine used in construction equipment? And can the engine serial number tell which equipment the engine was mounted original? Quote Link to comment Share on other sites More sharing options...
Nebraska1206 Posted November 23, 2022 Share Posted November 23, 2022 There were certain applications of the first DT361 engines, used in the construction & industrial lines, that were different from the engines in the 1206. The early ones used different turbocharger setups, and some had much larger, different oil filter setups, that are the same oil filters used on the DT429 engines. At the time of the DT361 engines, I don't believe the serial number stamp on the block will indicate what type of piece of equipment the engine was built for. That change didn't take place until the 1967 model year tractors, and the introduction of the DT407. Quote Link to comment Share on other sites More sharing options...
stronger800 Posted November 23, 2022 Share Posted November 23, 2022 I didn’t even know there was a 429. What was that ever in? Dozer? I want one 1 Quote Link to comment Share on other sites More sharing options...
DWF Posted November 23, 2022 Share Posted November 23, 2022 5 minutes ago, stronger800 said: I didn’t even know there was a 429. What was that ever in? Dozer? I want one TD-20 had them, Dirtboyz has one of them. Very un common engine. DWF Quote Link to comment Share on other sites More sharing options...
Farming Enthusiast Posted November 23, 2022 Share Posted November 23, 2022 18 minutes ago, stronger800 said: I didn’t even know there was a 429. What was that ever in? Dozer? I want one I am by far not as knowledgeable as a lot of these guys on here but I believe the 4156s have the 429. I bet that's a ballsy engine Quote Link to comment Share on other sites More sharing options...
Dirt_Floor_Poor Posted November 23, 2022 Share Posted November 23, 2022 17 hours ago, stronger800 said: I didn’t even know there was a 429. What was that ever in? Dozer? I want one TD-20B Dozer 250 & 250B Track Loader 4100 & 4156 Tractor H70(?) Wheel Loader I am working on a DT-429 in my track loader. Most parts are very difficult to find. There could have also been a few other applications. I know it was available as a power unit, I don’t know what they called it. UDT-429? Quote Link to comment Share on other sites More sharing options...
Farming Enthusiast Posted November 23, 2022 Share Posted November 23, 2022 1 hour ago, Nebraska1206 said: There were certain applications of the first DT361 engines, used in the construction & industrial lines, that were different from the engines in the 1206. The early ones used different turbocharger setups, and some had much larger, different oil filter setups, that are the same oil filters used on the DT429 engines. At the time of the DT361 engines, I don't believe the serial number stamp on the block will indicate what type of piece of equipment the engine was built for. That change didn't take place until the 1967 model year tractors, and the introduction of the DT407. Is the 429 a cousin of the 361/407 or a completely different engine? Quote Link to comment Share on other sites More sharing options...
Dirt_Floor_Poor Posted November 23, 2022 Share Posted November 23, 2022 Just now, Farming Enthusiast said: Is the 429 a cousin of the 361/407 or a completely different engine? The DT-429 is a wet sleeve engine. Quote Link to comment Share on other sites More sharing options...
Farming Enthusiast Posted November 23, 2022 Share Posted November 23, 2022 2 minutes ago, Dirt_Floor_Poor said: The DT-429 is a wet sleeve engine. Oh! Thanks! I thought maybe it was of the same design since they look similar on the outside. Quote Link to comment Share on other sites More sharing options...
Dirt_Floor_Poor Posted November 23, 2022 Share Posted November 23, 2022 Just now, Farming Enthusiast said: Oh! Thanks! I thought maybe it was of the same design since they look similar on the outside. The DT-429 also has a large engine oil cooler/water pump set up on the right side that would interfere with the frame rails on a row crop tractor. 1 Quote Link to comment Share on other sites More sharing options...
Matt Kirsch Posted November 23, 2022 Share Posted November 23, 2022 8 hours ago, Farming Enthusiast said: Oh! Thanks! I thought maybe it was of the same design since they look similar on the outside. I wonder if it might be, but in order to get the cubes they had to bore the block out and got into the water jacket, making it a wet sleeve. Of course both engines were designed around the same time so it's only logical they'd look similar. 1 Quote Link to comment Share on other sites More sharing options...
Rick G. Posted November 23, 2022 Share Posted November 23, 2022 Wasn’t there a thread here once about someone who put a DT 429 in a 1206, and they dubbed the tractor a 1406? Quote Link to comment Share on other sites More sharing options...
Nebraska1206 Posted November 23, 2022 Share Posted November 23, 2022 37 minutes ago, Rick G. said: Wasn’t there a thread here once about someone who put a DT 429 in a 1206, and they dubbed the tractor a 1406? Yep, Brad Twiss (IHBRAD) assembled & owns that tractor. Quote Link to comment Share on other sites More sharing options...
DT Fan Posted November 23, 2022 Share Posted November 23, 2022 37 minutes ago, Rick G. said: Wasn’t there a thread here once about someone who put a DT 429 in a 1206, and they dubbed the tractor a 1406? Yes! Been awhile back now. There used to be a video of it at plow-day on you-tube. I'll see if I can find it later. Nebraska 1206 beat to the punch! Quote Link to comment Share on other sites More sharing options...
Dirt_Floor_Poor Posted November 23, 2022 Share Posted November 23, 2022 50 minutes ago, Rick G. said: Wasn’t there a thread here once about someone who put a DT 429 in a 1206, and they dubbed the tractor a 1406? I believe IHBRADS tractor started life as an 806. Quote Link to comment Share on other sites More sharing options...
Tom560 Posted November 23, 2022 Author Share Posted November 23, 2022 Thank you all for the answers, I have here a Farmall 1206 sn 14100 that have now a 407tt engine in it. I want to make the tractor original with the dt361 engine, I can buy a dt361 engine out a scraper so when it fits I buy it to make the tractor original. 1 Quote Link to comment Share on other sites More sharing options...
Nebraska1206 Posted November 23, 2022 Share Posted November 23, 2022 23 minutes ago, Tom560 said: Thank you all for the answers, I have here a Farmall 1206 sn 14100 that have now a 407tt engine in it. I want to make the tractor original with the dt361 engine, I can buy a dt361 engine out a scraper so when it fits I buy it to make the tractor original. Where are you located, and what's your plans for the 407 engine? Quote Link to comment Share on other sites More sharing options...
stronger800 Posted November 23, 2022 Share Posted November 23, 2022 and if he’s closer to NY….i have the 361 here. Quote Link to comment Share on other sites More sharing options...
DT Fan Posted November 23, 2022 Share Posted November 23, 2022 1406 plowing; 2 Quote Link to comment Share on other sites More sharing options...
brahamfireman Posted November 24, 2022 Share Posted November 24, 2022 11 hours ago, Tom560 said: Thank you all for the answers, I have here a Farmall 1206 sn 14100 that have now a 407tt engine in it. I want to make the tractor original with the dt361 engine, I can buy a dt361 engine out a scraper so when it fits I buy it to make the tractor original. You'll have a million guys wanting that 407!!! Where are you located, lots of 806's around in junk yards, but not alot of good motors. Quote Link to comment Share on other sites More sharing options...
Rick G. Posted November 24, 2022 Share Posted November 24, 2022 21 hours ago, DT Fan said: 1406 plowing; Wow that’s awesome. But why did he censor / delete the close up side view of the DT 429 just as it drove by? Quote Link to comment Share on other sites More sharing options...
DT Fan Posted November 24, 2022 Share Posted November 24, 2022 34 minutes ago, Rick G. said: Wow that’s awesome. But why did he censor / delete the close up side view of the DT 429 just as it drove by? No idea. That was the best video I could find quick. Quote Link to comment Share on other sites More sharing options...
Tom560 Posted November 24, 2022 Author Share Posted November 24, 2022 I'm in the Netherlands, so that's far away from the most of you. The biggest problem here are spare parts for the Farmalls, they have never sold here so the spare parts I have to order in the USA Quote Link to comment Share on other sites More sharing options...
stronger800 Posted November 24, 2022 Share Posted November 24, 2022 Given that distance, I think I’d enjoy the 407 2 Quote Link to comment Share on other sites More sharing options...
DT Fan Posted November 24, 2022 Share Posted November 24, 2022 I understand you're wanting it to be original but in this case I'd leave the 407 in there! Be my little secret. 2 Quote Link to comment Share on other sites More sharing options...
