300 U engine rebuild
Well, I thought I was done rebuilding, but this came up. The starter ring gear is bad, so I thought I'd split the tractor and replace it. Then I thought you know it burns a little oil so why not do a head and ring job too. Well, the sleeves are up to .016 out of round so not just a ring job anymore! It has dry sleeves so is there any tricks to removing and replacing them? Bearings look like new, and it does have 60 pounds oil pressure when warmed up, so I think a sleeve, piston, ring kit will do. Any recommendation's as to where to buy them?
