acem Posted November 21, 2022 Share Posted November 21, 2022 The MCV on my 886 is leaking and I need to fix it. It's leaking from a shaft where I'm pointing my finger. I think it's the TA dump valve. What is involved in fixing this? I'm not very experienced with TAs... Thx-Ace Quote Link to comment Share on other sites More sharing options...
Farmall Doctor Posted November 21, 2022 Share Posted November 21, 2022 Clean it, remove the bracket, clean again. Remove cotter pin and clevis pin. Unthread the fitting. Replace seal and o-ring and re-assemble. 1 Quote Link to comment Share on other sites More sharing options...
Matt Kirsch Posted November 21, 2022 Share Posted November 21, 2022 1 hour ago, acem said: I'm not very experienced with TAs... Good thing you're nowhere near the TA, then Quote Link to comment Share on other sites More sharing options...
acem Posted November 22, 2022 Author Share Posted November 22, 2022 7 hours ago, Matt Kirsch said: Good thing you're nowhere near the TA, then I understand but most my other tractors don't have all this stuff. Quote Link to comment Share on other sites More sharing options...
stronger800 Posted November 22, 2022 Share Posted November 22, 2022 No other full size red tractors? Quote Link to comment Share on other sites More sharing options...
acem Posted November 22, 2022 Author Share Posted November 22, 2022 We don't normally have TAs on southern tractors. My 886 and 826 have TAs. My 504, 706, 856, 1066, 1086 and 1486 don't have TAs. My 4366 and hydro 186 weren't even available with a TA... Thx-Ace Quote Link to comment Share on other sites More sharing options...
Missouri Mule Posted November 22, 2022 Share Posted November 22, 2022 I'm not the expert here Ace but I've changed a few and I always take the time to run through all the adjustments on dump valve to trans brake. It's as good of time as any to keep them shifting good. 1 Quote Link to comment Share on other sites More sharing options...
