nate Posted November 18, 2022 Share Posted November 18, 2022 How do you service the hydro on this little fella? There is a drain at bottom of transmission, but when I started draining it the reservoir “cup” stayed full.. Quote Link to comment Share on other sites More sharing options...
Ruby Red Posted November 18, 2022 Share Posted November 18, 2022 All you can do is remove the cap from the reservoir and suck out as much oil as you can retrieve, refill with new high tran and good to go. Only other possibility is turn tractor up side down. Carl Quote Link to comment Share on other sites More sharing options...
nate Posted November 18, 2022 Author Share Posted November 18, 2022 Thanks Carl, I took the rear cover off the frame and found the fill plug for the transaxle. Changed that oil and will suck out the oil out of the cup as you suggest. Quote Link to comment Share on other sites More sharing options...
