826BB Posted November 16, 2022 Share Posted November 16, 2022 I just noticed that some MDs I see have a coil ignition and some have magnetos. I know the basic UD-6 gas start diesel engine was offered both ways but what is correct for a Farmall MD? And if it changed, was it different early vs late? Quote Link to comment Share on other sites More sharing options...
dale560 Posted November 16, 2022 Share Posted November 16, 2022 3 hours ago, 826BB said: I just noticed that some MDs I see have a coil ignition and some have magnetos. I know the basic UD-6 gas start diesel engine was offered both ways but what is correct for a Farmall MD? And if it changed, was it different early vs late? Not super 100% sure but I think a magneto was available option yet on super ms. Or even later tractors. I know MDs up here had more mag than distrubutor. 1 Quote Link to comment Share on other sites More sharing options...
DWV Posted November 17, 2022 Share Posted November 17, 2022 MD were only shown to come with a magneto. SMD could have a distributor. Unless the MD manifold was changed or parts in it the power to distributor would need a switch added to send power to or off. Original switch was at front of intake manifold with two studs for electric wire hookup. MD manifold only had one wire to magneto. Wire was ground and unground inside manifold. Distributors did get added to some MD tractors. Can't remember for sure at the moment if the distributors had 8-degree advance until some later ones changed to no advance. Most of SMD, 400D and 450D had the distributor standard. 2 Quote Link to comment Share on other sites More sharing options...
826BB Posted November 17, 2022 Author Share Posted November 17, 2022 9 hours ago, DWV said: MD were only shown to come with a magneto. SMD could have a distributor. Unless the MD manifold was changed or parts in it the power to distributor would need a switch added to send power to or off. Original switch was at front of intake manifold with two studs for electric wire hookup. MD manifold only had one wire to magneto. Wire was ground and unground inside manifold. Distributors did get added to some MD tractors. Can't remember for sure at the moment if the distributors had 8-degree advance until some later ones changed to no advance. Most of SMD, 400D and 450D had the distributor standard. Been doing a little more digging in books, catalogs and online and this looks to be correct. I found "magneto" listed in an early MD spec sheet and when I look at period images, every MD I see has a mag, and Hundred Series have coils. Didn't find many SMD pics but the couple I found had coils. Seemed like a simple question but it was a hard one to answer. I found any number of restored early MDs with coils. Quote Link to comment Share on other sites More sharing options...
DWV Posted November 18, 2022 Share Posted November 18, 2022 13 hours ago, 826BB said: Been doing a little more digging in books, catalogs and online and this looks to be correct. I found "magneto" listed in an early MD spec sheet and when I look at period images, every MD I see has a mag, and Hundred Series have coils. Didn't find many SMD pics but the couple I found had coils. Seemed like a simple question but it was a hard one to answer. I found any number of restored early MDs with coils. Thinking IH offered a battery ignition package at one time. Looked in a TC-28-H parts book printed in 1960. It shows a battery ignition attachment for a MD. But some parts of distributor in attachment not around when MD was built. TC-28-G printed August of 52 shows no distributor for a MD. 3 Quote Link to comment Share on other sites More sharing options...
Diesel Doctor Posted November 18, 2022 Share Posted November 18, 2022 The early gas start diesels used magnetos when designed. Some time later, they changed over to battery ignition. When I cannot say. All I know is you will find them both ways. You will have to dig deeper to find the serial number break when it happened. 1 Quote Link to comment Share on other sites More sharing options...
nepoweshiekfarmalls Posted November 18, 2022 Share Posted November 18, 2022 My 1950 MD has a magneto. 1 Quote Link to comment Share on other sites More sharing options...
DWV Posted November 20, 2022 Share Posted November 20, 2022 Found more info after looking on the subject dated 3-10-55. Later TC 28-H shows both the 8-degree parts and 0-degree parts that came out later. 2 Quote Link to comment Share on other sites More sharing options...
hardtail Posted November 21, 2022 Share Posted November 21, 2022 My 55 TD18 has a distributor to narrow down your timeline 1 Quote Link to comment Share on other sites More sharing options...
826BB Posted November 21, 2022 Author Share Posted November 21, 2022 Mainly wanted to confirm that in the MD days (no Super, etc.) they were factory equipped with magnetos. I know of a '52 TD9 that has a mag from the factory and the spec sheet so indicates. Quote Link to comment Share on other sites More sharing options...
