lorenzo Posted November 15, 2022 Share Posted November 15, 2022 I keep hearing about the importance of changing the antifreeze in modern ( aluminum ) engines these days due to the fact that the anti corrosion properties in the mix weaken over time and become basically non existent. Ok i can see that i guess, so at what intervals do you think it should be preformed. 50,000 miles, 100,000 miles? Or is it not that big of a deal? Quote Link to comment Share on other sites More sharing options...
sandhiller Posted November 15, 2022 Share Posted November 15, 2022 22 minutes ago, lorenzo said: I keep hearing about the importance of changing the antifreeze in modern ( aluminum ) engines these days due to the fact that the anti corrosion properties in the mix weaken over time and become basically non existent. Ok i can see that i guess, so at what intervals do you think it should be preformed. 50,000 miles, 100,000 miles? Or is it not that big of a deal? I think it depends on the antifreeze used. Just got the Pete back out of the shop and mechanic told me if we would run the extended range (pink, I think) we could go 3-500,000 miles between changes. 2 Quote Link to comment Share on other sites More sharing options...
Gearclash Posted November 15, 2022 Share Posted November 15, 2022 I would guess calendar time is a factor as well as hours or miles of use. The chemistry between coolant and engine components is going on 24/7. Looking in the water jacket of a “modern” engine that used better coolants and hasn’t had the decades of neglect vs the horrors one will find in say a letter series Farmall will make a person a quick believer in using a quality coolant and also in occasional coolant changes. 2 Quote Link to comment Share on other sites More sharing options...
dale560 Posted November 15, 2022 Share Posted November 15, 2022 2 hours ago, lorenzo said: I keep hearing about the importance of changing the antifreeze in modern ( aluminum ) engines these days due to the fact that the anti corrosion properties in the mix weaken over time and become basically non existent. Ok i can see that i guess, so at what intervals do you think it should be preformed. 50,000 miles, 100,000 miles? Or is it not that big of a deal? Some are 50,000 or less some mfg are 100,000 or a bit more. I would change it before a 100,000 just because modern engines makeup of parts can be corroded or eroded from different chemistry. 2 Quote Link to comment Share on other sites More sharing options...
nomorejohndeere Posted November 15, 2022 Share Posted November 15, 2022 depends on how much it costs to replace what is damaged by not changing it out. additives are available to renew I dunno, maybe more often as the engine gets older and has more crud deposits etc. I'd be more concerned about how long it was in there vs. how many miles.......... What does your owners manual suggest? 2 Quote Link to comment Share on other sites More sharing options...
885 Posted November 16, 2022 Share Posted November 16, 2022 8 hours ago, lorenzo said: I keep hearing about the importance of changing the antifreeze in modern ( aluminum ) engines these days due to the fact that the anti corrosion properties in the mix weaken over time and become basically non existent. Ok i can see that i guess, so at what intervals do you think it should be preformed. 50,000 miles, 100,000 miles? Or is it not that big of a deal? I know several manufacturers recommend replacing coolant at 100k. Part of the replacement has to do with the coolant additive package breaking down over time and the coolant becoming acidic. Which can react with the aluminum and induce voltage, I've heard up to around .5 volts, which in turn can cause problems with anything grounded to the engine block. Essentially it makes the car act like it has a bad ground 2 Quote Link to comment Share on other sites More sharing options...
England806 Posted November 16, 2022 Share Posted November 16, 2022 I used to use the old ethylene glycol based stuff. Changed about every three years then switched to the premixed extended life coolant. So far the old Landrover engine at 480000 miles is corrosion free. Seems to work pretty good. 3 Quote Link to comment Share on other sites More sharing options...
jeeper61 Posted November 16, 2022 Share Posted November 16, 2022 If you are using the concentrate mix with distilled water most of the corrosion issues start with well water 2 Quote Link to comment Share on other sites More sharing options...
Ihfan4life Posted November 16, 2022 Share Posted November 16, 2022 26 minutes ago, jeeper61 said: If you are using the concentrate mix with distilled water most of the corrosion issues start with well water For the savings, buy the premixed… it’s not much more when all is said and done 3 Quote Link to comment Share on other sites More sharing options...
jass1660 Posted November 16, 2022 Share Posted November 16, 2022 Shouldn’t use distilled water. https://rislone.com/blog/cooling/why-you-should-never-use-distilled-water-in-your-cooling-system/ 1 Quote Link to comment Share on other sites More sharing options...
Diesel Doctor Posted November 16, 2022 Share Posted November 16, 2022 Antifreeze is one area where I am dumber than a post. What is the best way to test antifreeze, not for how cold it will withstand, but for the additives still in it? I use the orange GM stuff in my Silverado and am in the process of changing a heater core. What ways are there to test antifreeze? I have some test strips but they will not work with the orange stuff. Other than replacing, is there additives one can add to it to bring it back to where the additives should be? I used Royal Purple, Purple Ice in my 350 Chevy after an overhaul and new green antifreeze. Is this any good. Hope this is not starting an oil thread? 1 Quote Link to comment Share on other sites More sharing options...
New Englander Posted November 16, 2022 Share Posted November 16, 2022 2 hours ago, Diesel Doctor said: Antifreeze is one area where I am dumber than a post. What is the best way to test antifreeze, not for how cold it will withstand, but for the additives still in it? I use the orange GM stuff in my Silverado and am in the process of changing a heater core. What ways are there to test antifreeze? I have some test strips but they will not work with the orange stuff. Other than replacing, is there additives one can add to it to bring it back to where the additives should be? I used Royal Purple, Purple Ice in my 350 Chevy after an overhaul and new green antifreeze. Is this any good. Hope this is not starting an oil thread? What I've done is just replace what I lost when replacing water pumps in the GM engines with the orange GM stuff and carry on. We had one Suburban that needed a pump around 100K and again about a 100 later and what I could see looked like brand new inside. Did the core go bad from the outside - standing water, or from inside? 2 Quote Link to comment Share on other sites More sharing options...
jeeper61 Posted November 16, 2022 Share Posted November 16, 2022 4 hours ago, jass1660 said: Shouldn’t use distilled water. https://rislone.com/blog/cooling/why-you-should-never-use-distilled-water-in-your-cooling-system/ That is good to know The most important part is However, if you use Hy-per Lube Super Coolant, you don’t need to use softened water. 3 Quote Link to comment Share on other sites More sharing options...
dale560 Posted November 16, 2022 Share Posted November 16, 2022 They tell us at training water is one of the best natural solvents there is. Meaning it will dissolve and carry most natural minerals if given enough time. So yes hard water will let stuff deposit out and distilled water will absorb minerals or metals seeking its equilibrium. 1 Quote Link to comment Share on other sites More sharing options...
hardtail Posted November 17, 2022 Share Posted November 17, 2022 I've always heard about this hungry water and I guess ionically it makes some sense, I have been involved in a lot of water purification but am no means an expert. Many different methods distillation, reverse osmosis, softeners, dealkalizers, deionizers etc. We have used them all in water treatment in power plants, I will say the best example is one facility that has used RO for feed water but not since day 1, waterside inspection still shows blue steel like the day it was assembled 30 years later, that plant has always exceeded their sodium sulfite range and I attribute that more than the water... I would say in gas engines the dissimilar metals contribute more than any other factor...if water that had fairly good parameters and additives from day one was used, we had a guy from the plant that would add a little moly to his truck every couple years, he had good results but other guys that didn't had the same 🤷♂️ 2 Quote Link to comment Share on other sites More sharing options...
Rawleigh99 Posted November 17, 2022 Share Posted November 17, 2022 I am using Cat EC-1 rated extended life coolant in everything right now. Right or wrong. 500,000 mile interval and then you can just add their conditioner for another 500K. You do need to thoroughly flush the system before you change it. 1 Quote Link to comment Share on other sites More sharing options...
ihrondiesel Posted November 17, 2022 Share Posted November 17, 2022 16 minutes ago, Rawleigh99 said: I am using Cat EC-1 rated extended life coolant in everything right now. Right or wrong. 500,000 mile interval and then you can just add their conditioner for another 500K. You do need to thoroughly flush the system before you change it. That brings up another point—thoroughly flushing the system. More than just filling and emptying a couple times. Quote Link to comment Share on other sites More sharing options...
Rawleigh99 Posted November 17, 2022 Share Posted November 17, 2022 Yep, Cummins makes a good flush. When I changed I ran the garden hose in the radiator hose with the engine running for about 30 minutes, ran the flush and then ran it on clean distilled water for 2 more flushes until it ran clear when I sampled the overflow. Then added the concentrate antifreeze followed by topping it up with RO water from a friend's car wash. That was a little overkill since it had that crappy Ford Gold coolant that turns to snot and plugs the EGR cooler. I also run a coolant filter on it too. Quote Link to comment Share on other sites More sharing options...
Diesel Doctor Posted November 18, 2022 Share Posted November 18, 2022 I used to use about an 1/8 cup of Sioux Valve Grinding Oil concentrate in a cooling system. It was dark like oil, turned the water milky and was a water soluble oil. It would remove, in about 30 days, all the white deposits on the tubes in the radiator. After that same period, the brass inside the radiator was a shiny as a new penny. And it lubed the water pump. It was great stuff but I cannot find it anymore. Quote Link to comment Share on other sites More sharing options...
New Englander Posted November 18, 2022 Share Posted November 18, 2022 1 hour ago, Diesel Doctor said: I used to use about an 1/8 cup of Sioux Valve Grinding Oil concentrate in a cooling system. It was dark like oil, turned the water milky and was a water soluble oil. It would remove, in about 30 days, all the white deposits on the tubes in the radiator. After that same period, the brass inside the radiator was a shiny as a new penny. And it lubed the water pump. It was great stuff but I cannot find it anymore. You're showing your age. Brass radiators? 😁 Quote Link to comment Share on other sites More sharing options...
Matt Kirsch Posted November 18, 2022 Share Posted November 18, 2022 On 11/16/2022 at 7:35 AM, jass1660 said: Shouldn’t use distilled water. https://rislone.com/blog/cooling/why-you-should-never-use-distilled-water-in-your-cooling-system/ So where do you get "softened water?" I've gone to many different stores and you can get distilled water, purified water, or spring water. Purified and spring water are both filtered by reverse osmosis. I just use 50/50 premix. Most of the cost of a gallon of antifreeze is packaging, shipping, and marketing, so this whole claim of being "cheated" is false. Plus I don't have to find another jug to mix in, and there's no question of using the "wrong water." Oh and by the way, I think the coolant should be changed per the interval stated in the owner's manual. Quote Link to comment Share on other sites More sharing options...
oleman Posted November 18, 2022 Share Posted November 18, 2022 This is another oil thread. I use premixed Walmart coolant in my equipment, says on the label it blends with all other coolants. I have an all aluminum Honda water cooled generator that I used Walmart in, no issues observed. I changed the evaporator on our 93 K2500 Suburban, so difficult to get at the evaporator I changed the heater core too. It was actually leaking enough to wet the core seam BUT after 29 years of multiple Coolant mixes I still use Walmart. The evaporator was also leaking BUT can't blame that on the coolant mix. Once many years ago, we used ditch run off water in an old Ford when it over heated, figured that it was better to use muddy water than walk. On a steam powered ship the boiler water was double distilled and then mixed with the proper chemicals to meet the correct chemistry. We used the same water without any chemicals in the cooling systems we used on the radars and other equipment. Our drinking waster was single distilled but BROMIDE added to reduce bacterial formation. COFFEE was better without the bromide, so we would use the drinking water - bromide, occasionally for coffee. FOR you medical types. The evaporators used on a ship operate at a vacuum and temperatures too low to sterilize the water so sterilization chemicals are used for (potable) drinking water. . 1 1 Quote Link to comment Share on other sites More sharing options...
MinnesotaFarmall Posted November 19, 2022 Share Posted November 19, 2022 On 11/15/2022 at 3:13 PM, lorenzo said: I keep hearing about the importance of changing the antifreeze in modern ( aluminum ) engines these days due to the fact that the anti corrosion properties in the mix weaken over time and become basically non existent. Ok i can see that i guess, so at what intervals do you think it should be preformed. 50,000 miles, 100,000 miles? Or is it not that big of a deal? How much does it leak? Like a good ole small block Ford, if it leaks or burns it, it will always have fresh oil in it 🤣🤣 1 Quote Link to comment Share on other sites More sharing options...
lorenzo Posted November 19, 2022 Author Share Posted November 19, 2022 13 hours ago, MinnesotaFarmall said: How much does it leak? Like a good ole small block Ford, if it leaks or burns it, it will always have fresh oil in it 🤣🤣 Oil leak???? Hey man its a Ford 1 Quote Link to comment Share on other sites More sharing options...
vtfireman85 Posted November 19, 2022 Share Posted November 19, 2022 21 hours ago, Matt Kirsch said: just use 50/50 premix. Most of the cost of a gallon of antifreeze is packaging, shipping, and marketing, so this whole claim of being "cheated" is false. Plus I don't have to find another jug to mix in, and there's no question of using the "wrong water." I too have started doing this, I figured whatever war is supposed to be in there is already there so I don’t have to worry about it, and i also don’t have to worry about my mix ratio getting off Quote Link to comment Share on other sites More sharing options...
