KDoersom Posted November 12, 2022 Share Posted November 12, 2022 On working on my sons Farmall 300 we were getting water in the number 1 cylinder. Today we found a crack in the sleeve that appears to be where the water is coming from. Since the C169 is a dry sleeved engine I’m assuming there is a crack in the blocks water jacket. The crack is on the rear of the number 1 cylinder So the question is can this have a repair sleeve installed to fix the issue if the crack isn’t to bad in the block. What’s your opinion? Quote Link to comment Share on other sites More sharing options...
JDpartsman Posted November 12, 2022 Share Posted November 12, 2022 Have to get it apart and see what your local machine shop has to say. Quote Link to comment Share on other sites More sharing options...
snoshoe Posted November 12, 2022 Share Posted November 12, 2022 A repair sleeve will fix it. Quote Link to comment Share on other sites More sharing options...
bitty Posted November 12, 2022 Share Posted November 12, 2022 I'd try to get a good used block , should be easily available. Once a crack starts it's hard to keep from spreading 1 Quote Link to comment Share on other sites More sharing options...
Diesel Doctor Posted November 12, 2022 Share Posted November 12, 2022 You need to pull that sleeve first to see if the block is cracked. Then take the bare block and that cracked sleeve to your machinist and see what the expert says. Jdpartsman also agrees! Quote Link to comment Share on other sites More sharing options...
snoshoe Posted November 12, 2022 Share Posted November 12, 2022 The antifreeze leak should tell you the block is cracked. As long as the deck and the bottom are not cracked. A repair sleeve will fix. 1 Quote Link to comment Share on other sites More sharing options...
ksfarmdude Posted November 12, 2022 Share Posted November 12, 2022 That happened on my Super M 30 years ago I found another block and overhauled that its still going strong 1 Quote Link to comment Share on other sites More sharing options...
MacAR Posted November 12, 2022 Share Posted November 12, 2022 A good shop could weld the block up, and then all you'd have to do is get a set of sleeves. If the block can be saved, go ahead and bore it to accept the C175 sleeves. Worst case, another block would be easy found. Go ahead and put a C175 in it if you do have to replace it, you'll get a bit more power that way. Mac Quote Link to comment Share on other sites More sharing options...
snoshoe Posted November 12, 2022 Share Posted November 12, 2022 Boring for a 175 sleeve will not repair it. However a repair sleeve can be sized to accept a 175 sleeve. A block that has already proven to be on the thin side would be a poor choice for an overbore kit. Unless repair sleeves are used in all bores Quote Link to comment Share on other sites More sharing options...
hillman Posted November 13, 2022 Share Posted November 13, 2022 OK, although I am not a senior 🐺 am I having senior's moment? the parent bore of a C169 and C175 are the same I have a c169 and a C175 both running engines that smoke I will sell if you are afraid of the repair sleeve.........its a common practice though nothing to be concerned about 1 Quote Link to comment Share on other sites More sharing options...
snoshoe Posted November 13, 2022 Share Posted November 13, 2022 54 minutes ago, hillman said: OK, although I am not a senior 🐺 am I having senior's moment? the parent bore of a C169 and C175 are the same I have a c169 and a C175 both running engines that smoke I will sell if you are afraid of the repair sleeve.........its a common practice though nothing to be concerned about Well I guess I qualify but no excuse. Thanks Quote Link to comment Share on other sites More sharing options...
hillman Posted November 13, 2022 Share Posted November 13, 2022 33 minutes ago, snoshoe said: Well I guess I qualify but no excuse. Thanks once I reach that age I will compound the " moments" with my brain cramps Quote Link to comment Share on other sites More sharing options...
MacAR Posted November 13, 2022 Share Posted November 13, 2022 2 hours ago, hillman said: OK, although I am not a senior 🐺 am I having senior's moment? the parent bore of a C169 and C175 are the same I'm not a senior either, but it seems I had a moment as well. I'm fairly certain you're correct, and if it wasn't so bloody cold I'd slip out to the shop and consult my shop manual to verify as much. Mac Quote Link to comment Share on other sites More sharing options...
