Tool ID thread
Sledgehammer
  • 4 weeks later...
  • 1 month later...
Anyone have an idea what this thing is?  Took a picture on a playing card for size perspective.  Maybe some type of pound in conduit hanger?IMG_0770.thumb.jpeg.3c84e066586a10a9b5df2490c63124b2.jpeg
Odd hammer in the batch is cast, says 13 on it, feels like pounds, but what is it for in particular? The lot a garage sale batch $20.IMG_0827.thumb.jpeg.729c6893ac43b8bbc0c10b9600d2dd63.jpegIMG_0825.thumb.jpeg.0249322121f8004717fa26ee615c577c.jpeg
Post maul. Used to be one on every farm. Most were 16 pounders.
Yep. Didn’t have them around here but that’s what it is. All the holes here were dug vs pounded as far as I can tell. No hedge posts straight enough to pound I guess 😊
Indeed. We have several of those. From 10 up to 16lb. A few have pockets in the face from someone pounding T posts in. I've only used them on cedar posts. A weekend of fencing with them can wear a fella out too. It was a good buy at $20. I've seen them going for as high as $75 around here.
The driver isn’t chipped much. The shovels don’t have much wear on the edges or handles however he did like to grind that ax ….a little wonky , easy fix.
  • 1 month later...
I used this homemade pry bar to install the fwa driveshaft in a neighbors tractor. I couldn't get a bigger bar in there to hold up the end and align t splines into the differential.
Can anybody identify what it's made from?
It’s hard to say, it like 3/8 round stock, and I would guess you chose something that was tough to start with. I am going to guess a rod from a camper shell door lock??
44 minutes ago, Alan Dinan said:
Found this in a shed we’re tearing down. Can’t find anything on the inter web from the number.
Is this the handle to a stove to, "Shake Your Grates".
I'm not certain that's a wrench. If it is, it isn't one I've seen before.
I thought that, but what’s the square hole for, flue adjuster?
 I couldn’t find anything from the number on it.
The stove comment got me thinking. The square end could fit end of shaft of rocker grates in a coal stove and the other end could be a lid lifter. Should be bent a little different for that and lid end should be flatter and have a little hook. So don't think so.
Well, a square nut. I have a bunch of old cast iron wrenches with square holes. But still, that other end gives me pause.
Lid lifters are normally smaller from what I’ve seen??  That looks heavy enough to lift the stove….
Square is the preferred shape for many shafts on machinery, likely shipped with a piece of equipment.
Picked up this shear today. I don’t think I’ve ever seen a small one. It does 1/8”-3/8”. Most of of the ones I have seen were larger.
On 7/17/2023 at 10:32 AM, ray54 said:
Maybe wood stove lids are different than a coal stove.  I think it looks like I could lift a stove lid with it.
If you turned it over I reckon it would work with stove lids I've seen (and lived with, including cutting the wood)
