66 series Ambac 100 inj. pump primer
1566Hog
I have a 1066 that got ran out of fuel.  When I went to prime the fuel system, the hand primer just leaked fuel everywhere. Every time I stroked the hand pump, diesel was spraying everywhere. It was to the point that I thought about stopping because it was making such a mess.
So, what is worn out?  Is it the brass sealing washer/ring at the bottom of the primer, or is it o-rings somewhere?  Or does it call for a new primer?
Thanks.
Thanks.
Those are easliy replaceable get a new one and screw it on
I was just wondering what was worn out. If it was just an o-ring, I’d replace it and try it. Just was curious about what is actually causing it to leak.
A lot of times the plastic plunger is scored or damaged not worth screwing with replace the whole plunger body
Primer assm # 680391C91
Parts below are for replacing the quad ring in the plunger
sq. ring # 1802465C1
Copper ring # 681298C1
o-ring # 238-5113
I have been able to replace the seal and oring with good results. Might find the parts cheaper at pump shop.
9 hours ago, Dan Robinson said:
Plastic plunger? Can't say I've seen one made out of plastic.
Your right My Bad I was thinking of the inline pump , good call
That plunger is steel unless there is someone making an aftermarket plastic one ? After you thread that plunger assembly  out of the transfer pump , then extend the plunger and put a shop towel around the plunger and clamp it in the vise . The top knob threads off the plunger and then slide the plunger out the bottom . Like the other guys are telling you just replace the square oring and the copper washer in the bottom of the transfer pump and your good to go 👍 Your local fuel shop will have those two parts you need too if you can’t get them from CNH
Danny
4 hours ago, acem said:
My closest dealer is an hour and a half away anddon'tstock this stuff.
I get most of  my orings, etc from RGA about half as far away. RGA has an amazing amount of stuff.  Any good hydraulic shop should have these as well.
https://rgausa.com/
  Any International Truck dealer will be able to get these, too.
