Sam_SWIN Posted November 5, 2022 Share Posted November 5, 2022 Have a IH 392 in a 1983 S1700 and the carb on it is in bad shape from sitting the secondaries are frozen. The primaries are extremely stiff even after sitting in chem dip. Does someone have a source or know of something that will directly bolt up to this? I’m pretty dumb when it comes to carburetors so any help is appreciated. This one is a Holley and I assume it’s easiest to replace with a Holley. It is electronically governed but manual choke. Thanks Quote Link to comment Share on other sites More sharing options...
1066 Peterbilt Posted November 24, 2022 Share Posted November 24, 2022 A common 600 Holley or Edelbrock will bolt up. You will however loose your governor and throttle kicker. Those carbs were always expensive. Maybe try carburetor specialist in Atlanta it they are still around. Quote Link to comment Share on other sites More sharing options...
