666 front end swap
1955farmall400
Hey guys, I just picked up a 666 with a wide front and was looking at eventually swapping it to a narrow front end. My question is what all narrow front bolsters would be compatible with that tractor?
I think from a light 460 through a heavy 1456, 1066 T post will fit. The small frame already has the wet bolster the same as the older series so nothing as far as the bolster should need changed.
If you can find a post with hubs that would be the easiest, I know there are differences in some hub/bearing sizes as far as what fits and what won't but I don't know what they are. I think the 460 type or early/light posts used smaller bearings then were used on like a 706 post.
The bolster does not need to be changed. That's the part that bolts into the frame and contains the "turny part."
Just unbolt the wide front and bolt the narrow front (sometimes called a "pedestal") to the plate where the steering arm for the wide front was.
Ah yes that's the word i was looking for. So will the pedestal off a 4 or 560 fit? They seem to be the most plentiful in my area.
3 minutes ago, 1955farmall400 said:
Too far away unfortunately
Yea I undertand sorry , the 656 narrow fronts had the smaller sized bearings and hubs
If it has a loader on it look for a 560, 706, 806. Most 460/656's had the small spindles and bearings. The small spindle used a 3/4 nut and the large a 7/8 nut.
