seabee Posted November 2, 2022 Share Posted November 2, 2022 How much hyd presure can I get out of a 560 and how can I increase Quote Link to comment Share on other sites More sharing options...
snoshoe Posted November 2, 2022 Share Posted November 2, 2022 Rated pressure is 1200 psi. It can be raised by shimming relief valve. Question is how much do you have now and how much do you need? Quote Link to comment Share on other sites More sharing options...
seabee Posted November 2, 2022 Author Share Posted November 2, 2022 Have 1500 need as much as I can practablly get Quote Link to comment Share on other sites More sharing options...
snoshoe Posted November 2, 2022 Share Posted November 2, 2022 Pump could probably handle it. Not so sure about the rest. At some point the flexing is going to cause blown orings and breaking bolt. Probably need to add an inner spring to relief to achieve. I would look to adding auxiliary system to achieve instead of risking what you have. Quote Link to comment Share on other sites More sharing options...
