Binderdan Posted November 1, 2022 Share Posted November 1, 2022 My Farmall 856 came with a set of M&W 9 bolt dual hubs. A few of the studs on the hub are bent and some have damaged threads. Is there a source to buy new studs and nuts for these hubs? Or do I just need to drive one out and search automotive and truck stud books to find new ones by size? I have tried the Google machine to no avail. Quote Link to comment Share on other sites More sharing options...
bitty Posted November 1, 2022 Share Posted November 1, 2022 I'm not sure about those but I have found at truck garage ones we needed for a manure tanker Quote Link to comment Share on other sites More sharing options...
ksfarmdude Posted November 1, 2022 Share Posted November 1, 2022 Pics would help but you can try doorman fastener products or remove the studs and use tapered head bolts not sure what your wheel will accept Quote Link to comment Share on other sites More sharing options...
Dzldenny Posted November 1, 2022 Share Posted November 1, 2022 I purchased some DMI hubs that needed help for my 1206 this spring. I drilled out each of the holes and tapped them 7/8-14. I ordered threaded inserts (Zoro# G4309858) and the installation tool (Zoro# G4305895). These inserts are internally threaded for 5/8-18. I ordered my studs as well as jam nuts from Schoup. Best prices I could find as of spring. Shoup also has press in studs. 5 Quote Link to comment Share on other sites More sharing options...
Wi Ih Posted November 1, 2022 Share Posted November 1, 2022 Go to the parts store with old one, that’s where I got mine Quote Link to comment Share on other sites More sharing options...
Dzldenny Posted November 1, 2022 Share Posted November 1, 2022 Schoup was around $2 each in spring if I recall. Pa paid $18 each at the implement for studs when he replaced some stripped ones on one of his sets. He was ticked when I showed him what I paid. There is something to be said for doing business local. I'm all for it. But, I ordered studs for both the hubs and spacers along with nuts and a few extra to keep on hand if something gets damaged. There was just too much difference in cost for me at the time. If I would need one or two, I couldn't pay the difference for the shipping and would run to the implement too. It worked out best for me because I was redoing the whole set. I just thought I'd share so you could decide if you wanted to replace a few or redo the whole set. I will say. It was nice to have all new hardware and not worry about sorting nuts with iffy threads to put on studs with crumby threads etc. Quote Link to comment Share on other sites More sharing options...
Binderdan Posted November 2, 2022 Author Share Posted November 2, 2022 Thanks for the replies. I was hoping someone was still supporting the M&W products and I could just order some. Guess I'll just pound one out when I get home from deployment and find new ones from the dimensions. I agree Dzldenny, starting with all new ones would be the way to go. They are all a little iffy. Especially the right side after I got too close to a guard rail on the highway once. Your internal thread conversion is probably easier to swap studs when needed I will look into this Schoup place. Otherwise I have an old NAPA catalog somewhere for studs and nuts. Quote Link to comment Share on other sites More sharing options...
Dirt_Floor_Poor Posted November 2, 2022 Share Posted November 2, 2022 8 minutes ago, Binderdan said: I will look into this Schoup place. I think they mean Shoup Manufacturing. 1 Quote Link to comment Share on other sites More sharing options...
801486 Posted November 2, 2022 Share Posted November 2, 2022 Everything I've needed for dual hubs I got at the John Deere dealer, Case IH had the same stuff, but was 2-3 times higher. 1 Quote Link to comment Share on other sites More sharing options...
Dzldenny Posted November 2, 2022 Share Posted November 2, 2022 First and foremost... Thank you for your service. Here's a link to the studs, nuts, and bolts. https://www.shoupparts.com/products/hubs-spindles-wheels/wheel-bolts-and-nuts/ 1 Quote Link to comment Share on other sites More sharing options...
JaredT Posted November 2, 2022 Share Posted November 2, 2022 Thank you for your service Binderdan, may you have a speedy and safe deployment. They are talking about shoupparts.com, they supply all kinds of stuff, reasonably and from what we have seen, pretty good quality. Good luck with it. 1 Quote Link to comment Share on other sites More sharing options...
DT Fan Posted November 2, 2022 Share Posted November 2, 2022 Had to insert some holes in the DMI hubs on my 10 some years back. Four in one and I don't remember on the other. Used Jergenserts, not my favorite insert but what I could get. Drilled them smaller than the instructions called for, just big enough for them to screw in. The hubs JUST fit on my little drill press. Seems like I used some red Loctite too. Anyway, several years later, and the duals never come off, no problems encountered. Quote Link to comment Share on other sites More sharing options...
Binderdan Posted November 3, 2022 Author Share Posted November 3, 2022 Thanks for your support! Just a few months to go. That's a good selection on the Shoup Parts website. I'll get one drove out when I get home and measure. If the knurl is worn out in the hole I will probably drill out and do inserts. Gives me a backup option. Thanks everyone! Quote Link to comment Share on other sites More sharing options...
ksfarmdude Posted November 4, 2022 Share Posted November 4, 2022 I had M&W dual hubs on my 1086 those use a 5/8 fine thread bolt I had afew strip out but didn't worry about it much Quote Link to comment Share on other sites More sharing options...
