OSHA approved?
Only RED in the shed
3 hours ago, Only RED in the shed said:
Am I the only one who would do questionable stuff like this? Broke range linkage and trying to get at it.i know they upside down
I would say anyone who actually is trying to get work done does stuff like this once in a while.  Just do the best you can as far as supporting it so it cannot fall on you while you are in there.
10 hours ago, Only RED in the shed said:
Hey,thanks for flipping them over.what do I need to change to get pics right side up
I downloaded them, then clicked to edit each one, flipped them so they were right and uploaded them. I have went to attach pictures before and if they show that they are upside down before you insert them they will stay that way.
17 hours ago, Only RED in the shed said:
All that and it was just broke roll pin,guess I might as well redo the lose linkage up top while I'm in there
Originally there is a solid groove pin in there rather than a roll pin. If you are going to use a roll pin add another inside the first one and then tie them in place with a wire running through them.
It looks like the same pin I had give out on my 1256 earlier this year. Wire is a good idea, I used a zip tie. Just don’t do what previous owner of my tractor did and weld it. I had a #%*! If a time getting the grinder in there to knock the weld off. That was after fighting it for awhile before I realized it was welded on the other side too.
