Upgrades for the 5X88 tractors
IH686neuss
Modern lighting. I run quadtracs at work and these new headlights like up a jobsite likes its noon and sunny!
2 hours ago, acem said:
@88seriesrestorer
Can you tell us more about the high efficiency cab fan?
Instead of having the center mointed motor that the squirrel cages beat the bushings out of and then over draw.  The hi eff fan each cage has its own motor.  No more outta balance, they move more air and are quiet
Do they make those for the boxcar magnums as well?
Thanks for the info Mike!
The tray that goes on top of the dash is very handy.
The extra lights on the front end weight bracket.
I would like to add idiot lights & alarm to all my tractors for temp & oil. My wife won't look at the guages like I do...
Magnum battery box and steps with both batteries on left side
magnum door hinges and latch
tray for dash is very nice and handy
air ride seat upgrades
LED lights all around including dash and inside cab.
auto steer systems are nice for long nights of field work
after market mirrors mounted on both sides.
sound proofing materials from Fehr Cab for floor and firewall and rear cab panels. Make them as quiet as the magnums. 1360332052_DSCF1966-Copy.thumb.JPG.ddb97f296cff64299c09ac57ac0b6bd5.JPG
Turbo upgrades and exhaust muffler eliminators help with lower exhaust temps and more HP
  • Like 7
  • 1 month later...
I did staet on that ive done that on some of my dads tractor good idea!
On 10/25/2022 at 7:14 AM, 88seriesrestorer said:
Make sure it has sentry in it first and foremost.  I have new ones.  Then look at fuse box and replace if melted.  Replace lights with leds, put in the high efficiency cab fan, and sanden comp setup.
Alright the owner said they put one in it several years ago. I will remeber the fan upgrade.  And check the compressor . I do have to work on the fuse panel its got issues.  Gonna replace it this winter witha fues panel or circut breakers
What did you do for turbo upgrades, its got a muffler delete
19 minutes ago, 5488Duke said:
Yes we did. It was a very nice upgrade.
Did you alter the factory door to resemble the Magnum door and did you do it to both sides of the tractor?
No we got a used magnum door. Just did the left hand side.  We have monitors and such blocking the right hand side so it really can’t be used.  But if you got all the parts and linkages for opener system and hinges, you could alter the door on right side.  Would be a lot more work.  We needed a door for the 5288 we had picked up about the same time. Its door was in real bad shape. So used the magnum door on 5488 and put the good 54 door on the 52 at the time.  Win win so to speak.
