Wisconsinred Posted October 22, 2022 Share Posted October 22, 2022 Long story short hot 1566 with a reman 466, main pto horse on our dairy. As it’s fall it’s been on the farmhand hammer mill The last few days. Uncle called at about load 10 yesterday and said it was pushing water out the overflow so he shut it down, we chalked that to be sudden high temps outside and maybe running a little to hard let it cool a while and everything was fine, except a faint noise behind the clutch, popped the bottom cover off and there laid the grease tube for the throw out bearing, I can’t see anything bent to make that noise, but idk it’s awful funny it’s ran 100’s of loads through that mill and suddenly boils the water almost like a bearing locked up or got tight. Loud as that mill is you’d never hear it in the moment he said he seen the water paniced shut everything down. Quote Link to comment Share on other sites More sharing options...
snoshoe Posted October 22, 2022 Share Posted October 22, 2022 Tooth out of pto gear. Next compartment back? Quote Link to comment Share on other sites More sharing options...
Wisconsinred Posted October 22, 2022 Author Share Posted October 22, 2022 Maybe sure sounds like it’s in the clutch housing but you very well could be right Quote Link to comment Share on other sites More sharing options...
mrfred54 Posted October 22, 2022 Share Posted October 22, 2022 Is pto and hydraulics still working, if so then maybe worth your time to remove the the speed transmission bottom cover and check for a broken tooth, like snowshoe said Quote Link to comment Share on other sites More sharing options...
Wisconsinred Posted October 22, 2022 Author Share Posted October 22, 2022 How much oil can I expect to drain? Quote Link to comment Share on other sites More sharing options...
catman13 Posted October 22, 2022 Share Posted October 22, 2022 it maybe your pto drive with broken rivits Quote Link to comment Share on other sites More sharing options...
Wisconsinred Posted October 22, 2022 Author Share Posted October 22, 2022 7 minutes ago, catman13 said: it maybe your pto drive with broken rivits I struggle with this because we ran it after that incident and it ran just fine. Quote Link to comment Share on other sites More sharing options...
catman13 Posted October 22, 2022 Share Posted October 22, 2022 the rivets may have sheared and now it is just binding and still working for now, just my quess Quote Link to comment Share on other sites More sharing options...
65806 Posted October 22, 2022 Share Posted October 22, 2022 Years ago we were doing PTO work with our 1066 and it started knocking. It was weird as it would be two small clicks than one louder knock. turns out it broke one tooth off of two of the gears so the two smaller clicks was when the small gear broken tooth hit a good spot on bigger gear but when both broken teeth lined up it would give out the louder knock. if I remember right we pulled the MCV and rolled the motor over by hand and could see the broken gear. 1 Quote Link to comment Share on other sites More sharing options...
snoshoe Posted October 22, 2022 Share Posted October 22, 2022 2 hours ago, Wisconsinred said: How much oil can I expect to drain? Normal fill on the level. Right around 5 gallons. Maybe a little more. Pointed uphill enough and an ice cream bucket will take care of it. 1 Quote Link to comment Share on other sites More sharing options...
Matt Kirsch Posted October 24, 2022 Share Posted October 24, 2022 On 10/22/2022 at 12:27 PM, Wisconsinred said: I struggle with this because we ran it after that incident and it ran just fine. So after you removed the grease tube, the clunk was gone? Quote Link to comment Share on other sites More sharing options...
Wisconsinred Posted October 25, 2022 Author Share Posted October 25, 2022 No noise Is still there. Dropping bottom cover today to see what I find, will post pictures later on today Quote Link to comment Share on other sites More sharing options...
88seriesrestorer Posted October 25, 2022 Share Posted October 25, 2022 Pto driven gear has tooth off Mike Quote Link to comment Share on other sites More sharing options...
MarkG Posted October 26, 2022 Share Posted October 26, 2022 We’re the pto gears a weak point on the large frame tractors? Quote Link to comment Share on other sites More sharing options...
88seriesrestorer Posted October 26, 2022 Share Posted October 26, 2022 No. You see this more on tractors that are used mostly used for pto work. Around here the tmr's get the best of them 1 Quote Link to comment Share on other sites More sharing options...
Diesel Doctor Posted October 26, 2022 Share Posted October 26, 2022 BIL used to explode the PTO system on a 1456 cranked up to 200 HP and on a tub grinder. He would do the double split to get the new shaft and gear in, in an evening. He got good at it. But that extra power got costly. Quote Link to comment Share on other sites More sharing options...
Wisconsinred Posted October 26, 2022 Author Share Posted October 26, 2022 10 hours ago, Diesel Doctor said: BIL used to explode the PTO system on a 1456 cranked up to 200 HP and on a tub grinder. He would do the double split to get the new shaft and gear in, in an evening. He got good at it. But that extra power got costly. It’s not so bad if I’m running it but throw uncle etc on there and let them get in a hurry or think there behind and it’s a different story. You have to respect that power. Quote Link to comment Share on other sites More sharing options...
Wisconsinred Posted October 26, 2022 Author Share Posted October 26, 2022 Thanks everyone in deed it was a tooth off the bottom gear. Looks like the clutch hub rivets are sloppy as well so who knows what else we will find I’ll post pics when we split it 2 Quote Link to comment Share on other sites More sharing options...
JT706 Posted December 26, 2022 Share Posted December 26, 2022 IH could’ve beefed up the PTO drive in their tractors. I have a 4186 that never had anything hooked to the PTO but at a clutch replacement at 3000 hours the PTO drive shaft splines were almost wore off like you’d used the PTO every day Quote Link to comment Share on other sites More sharing options...
Wisconsin Ron Posted December 26, 2022 Share Posted December 26, 2022 59 minutes ago, JT706 said: IH could’ve beefed up the PTO drive in their tractors. I have a 4186 that never had anything hooked to the PTO but at a clutch replacement at 3000 hours the PTO drive shaft splines were almost wore off like you’d used the PTO every day I not sure on 4186 but 706 on up drive hydraulics off them splines also. I imagine the steering taxes them splines on 4186 some. I could be wrong though. Quote Link to comment Share on other sites More sharing options...
ny bill o Posted December 26, 2022 Share Posted December 26, 2022 On 10/26/2022 at 7:15 PM, Wisconsinred said: Thanks everyone in deed it was a tooth off the bottom gear. Looks like the clutch hub rivets are sloppy as well so who knows what else we will find I’ll post pics when we split it wonder if that same gear is what is making the noise in my 1466? It was turned up to 200 hp when I got it, had it turned back to 180, but its done a lot of pto work, mostly running a 2 row chopper. Pics of the damage welcome. Quote Link to comment Share on other sites More sharing options...
