acem Posted October 20, 2022 Share Posted October 20, 2022 I have the opportunity to replace the rotor variable drive belt on my 1460 and was reading the instructions in a manual. It mentions compressor plate to open up the driven pulley. I don't have one of these. How helpful are these? Can someone post a pic? Thx-Ace Quote Link to comment Share on other sites More sharing options...
SDman Posted October 20, 2022 Share Posted October 20, 2022 Looks like this. Do what everyone else has been doing for 30+ years....take a 2×4 and make a wedge/point shape on one end and then drive it in between the pulley halves. The spring on those wasnt too strong so the wedge works just as good as the tool. 1 1 Quote Link to comment Share on other sites More sharing options...
Farmall Doctor Posted October 20, 2022 Share Posted October 20, 2022 I use a piece of 2x2 about 3” long to stuff down between the pulleys. Don’t bother swinging the gearbox both ways to change the belt either. Run the drive pulley all the way to slow position. Cut the old one off with a hacksaw. Feed the new one in (after disconnecting the driveshaft and getting the pulley motor up out of the way), get it seated in the drive pulley, start it in the driven pulley and use the big wrench to turn it all the way in. Quote Link to comment Share on other sites More sharing options...
WishIhada1466 Posted October 21, 2022 Share Posted October 21, 2022 I made one this week. More so for compressing the spring enough to get the snap ring off to replace the rollers. I did use it when I put the belt back on though. Quote Link to comment Share on other sites More sharing options...
acem Posted October 21, 2022 Author Share Posted October 21, 2022 Thanks y'all. Did combines come with one or is it a special tool? Cut the old belt off??? Mine always break when a slug of down rice hits the rotor!!! Quote Link to comment Share on other sites More sharing options...
Dirt_Floor_Poor Posted October 21, 2022 Share Posted October 21, 2022 You have the opportunity to replace the belt? Your attitude is better than mine if that means that you tore up the belt and now have to put a new one on. 1 1 Quote Link to comment Share on other sites More sharing options...
axial_al Posted October 21, 2022 Share Posted October 21, 2022 11 hours ago, acem said: Thanks y'all. Did combines come with one or is it a special tool? Cut the old belt off??? Mine always break when a slug of down rice hits the rotor!!! Both of the axial flows I have owned came with that tool wrapped up in some kind of oily cardboard. 1 Quote Link to comment Share on other sites More sharing options...
dale560 Posted October 21, 2022 Share Posted October 21, 2022 13 hours ago, acem said: Thanks y'all. Did combines come with one or is it a special tool? Cut the old belt off??? Mine always break when a slug of down rice hits the rotor!!! If you are breaking them constantly. The rollers and cam on torque sensor and the drive sheave need attention. You should kill the combine dead if a slug is big enough. You will ruin the belt slipping it to unplug rotor though if not careful. Seriously I know rice is the worst on parts but we use to fix dads combine up when he would tear belts on weedy crops. Unloading spring pressure on belt over off season is supposed to help also. Easiest way to describe belt action is a rotor slows down cams are supposed to take over and tighten belt more and change speed a bit. I always describe it as a way up here people understand. Snowmobiles are similar not the same but if you hot rod the heck out of the. You change belts along the trail. 1 Quote Link to comment Share on other sites More sharing options...
Farmall Doctor Posted October 21, 2022 Share Posted October 21, 2022 20 hours ago, acem said: Cut the old belt off??? If you are replacing it, why fight with taking it off? Quote Link to comment Share on other sites More sharing options...
snoshoe Posted October 21, 2022 Share Posted October 21, 2022 8 minutes ago, Farmall Doctor said: If you are replacing it, why fight with taking it off? You should have read one more line. 1 Quote Link to comment Share on other sites More sharing options...
acem Posted October 22, 2022 Author Share Posted October 22, 2022 It doesn't break the belt every time I plug the rotor. But every time I break a belt it's when the rotor plugs. I put two belts on when I take the drive shaft off. One goes on the rotor and the other is tied up for a spare. This time I put the spare on. It has been several years waiting in position but I have a feeling I may need another this season. The rice is pretty good and some has already gone down. Thx-Ace Quote Link to comment Share on other sites More sharing options...
acem Posted October 22, 2022 Author Share Posted October 22, 2022 Here's some down rice. Quote Link to comment Share on other sites More sharing options...
acem Posted October 22, 2022 Author Share Posted October 22, 2022 Her I'm unloading onto my eddins rice and bean cart. 5 Quote Link to comment Share on other sites More sharing options...
dale560 Posted October 22, 2022 Share Posted October 22, 2022 11 hours ago, acem said: Her I'm unloading onto my eddins rice and bean cart. Is that white rice? Fun seeing other kinds of farming going on. 1 Quote Link to comment Share on other sites More sharing options...
acem Posted October 23, 2022 Author Share Posted October 23, 2022 That's rough rice, Rough rice has a hull. Similar to oats. If you remove the hull you have brown rice. If you remove the bran you have white rice. 1 Quote Link to comment Share on other sites More sharing options...
acem Posted October 23, 2022 Author Share Posted October 23, 2022 Rough rice. Also called paddy rice, cargo rice, etc. 3 Quote Link to comment Share on other sites More sharing options...
acem Posted October 23, 2022 Author Share Posted October 23, 2022 Brown rice. 4 Quote Link to comment Share on other sites More sharing options...
acem Posted October 23, 2022 Author Share Posted October 23, 2022 White rice 4 Quote Link to comment Share on other sites More sharing options...
acem Posted October 23, 2022 Author Share Posted October 23, 2022 Rice also has many different types. Grain length. Short, medium and long. Flavors. Basmati, jasmine, etc. Colors (bran and/or center). Texture. Sticky, individual (not Sticky), etc. Cooking properties. It goes on. Ov course there are numerous varieties of each type. Most of the world has rice or wheat as the base of their diet (some both). Wheat is the king of temperate climates. Rice is king of the tropics. Corn is a major crop but is primarily animal feed. Thx-Ace 2 Quote Link to comment Share on other sites More sharing options...
acem Posted October 23, 2022 Author Share Posted October 23, 2022 Back to your original question. My rice is typical American long grain white rice like you would buy in the store. The variety is Jewel, a public variety from the Arkansas rice breeding program. Thx-Ace 1 Quote Link to comment Share on other sites More sharing options...
tractorholic Posted October 23, 2022 Share Posted October 23, 2022 On 10/20/2022 at 11:13 AM, Farmall Doctor said: I use a piece of 2x2 about 3” long to stuff down between the pulleys. Don’t bother swinging the gearbox both ways to change the belt either. Run the drive pulley all the way to slow position. Cut the old one off with a hacksaw. Feed the new one in (after disconnecting the driveshaft and getting the pulley motor up out of the way), get it seated in the drive pulley, start it in the driven pulley and use the big wrench to turn it all the way in. I’m not trying to argue with you… but depending on where that gearbox is I don’t see how you would get the new one on without moving that gearbox. Not to mention your going to have to loosen the bolts and set the tension on the new belt anyway. Or at least you should set the tension on the new one. Quote Link to comment Share on other sites More sharing options...
mrfred54 Posted October 23, 2022 Share Posted October 23, 2022 10 hours ago, acem said: Back to your original question. My rice is typical American long grain white rice like you would buy in the store. The variety is Jewel, a public variety from the Arkansas rice breeding program. Thx-Ace Thanks acme. That's awesome, just got a course in rice 101🤗 Quote Link to comment Share on other sites More sharing options...
dale560 Posted October 23, 2022 Share Posted October 23, 2022 13 hours ago, acem said: Rice also has many different types. Grain length. Short, medium and long. Flavors. Basmati, jasmine, etc. Colors (bran and/or center). Texture. Sticky, individual (not Sticky), etc. Cooking properties. It goes on. Ov course there are numerous varieties of each type. Most of the world has rice or wheat as the base of their diet (some both). Wheat is the king of temperate climates. Rice is king of the tropics. Corn is a major crop but is primarily animal feed. Thx-Ace Thanks for taking the time to explain. It is fun to see all types of ag. How to you seed rice? Regular disc type drill? Or special planter. Quote Link to comment Share on other sites More sharing options...
1480x3 Posted October 23, 2022 Share Posted October 23, 2022 7 hours ago, tractorholic said: I’m not trying to argue with you… but depending on where that gearbox is I don’t see how you would get the new one on without moving that gearbox. Not to mention your going to have to loosen the bolts and set the tension on the new belt anyway. Or at least you should set the tension on the new one. Have done at least a half a dozen of those the last 35 years, never messed with any gearbox. Just unhooked drive shaft and another small thing or 2, drive a piece of wood in pulley and your on your way. Was a half hour job when i was 30, today i would have to take a soda/candy bar break. Can turn pretty much anything into a 2 hour job any more Quote Link to comment Share on other sites More sharing options...
acem Posted October 24, 2022 Author Share Posted October 24, 2022 Rice can be planted with a grain drill in dry soil. This is the most common method in the Eastern rice producing areas. It can be flown into a shallow flood (water seeded). This is the most common method in California. In other countries, sometimes the seeds are started then transplanted into the water. not all rice is grown in water. Some rice is grown under center pivots or furrow irrigated (row rice). A friend grows rice in Guatemala without irrigation or flood. It grows similar to wheat. Monsoon Rains water it most every day during a wet season. Rice is actually drought tolerant but is also water tolerant. The flood makes weed and disease control easier. Rice will regrow after harvest and make another crop, similar to milo (sorghum), if there is sufficient growing season and moisture. This is common in Southern Louisiana, Texas, etc. It's called a ratoon crop. 1 Quote Link to comment Share on other sites More sharing options...
