2+2love Posted October 17, 2022 Share Posted October 17, 2022 Can I replace the king pin bearings without taking apart the planetary hub? Quote Link to comment Share on other sites More sharing options...
Torque Posted October 18, 2022 Share Posted October 18, 2022 Yes, the sun shaft will come out of the U-joint, the whole hub assembly will come off. But... check the wheel bearings to make sure they are tightened to spec, most are way loose by now. Loose bearings are the reason for wheel bearing failure. 1 Quote Link to comment Share on other sites More sharing options...
