IHC5488 Posted October 15, 2022 Share Posted October 15, 2022 Changed out the valve block and solenoid today on the hydraulic reverser, do these crack or fail often? Or is just as simple as rebuilding with new O-rings ? Quote Link to comment Share on other sites More sharing options...
tractorholic Posted October 15, 2022 Share Posted October 15, 2022 I’m curious why you changed yours? If it cracks, rebuilding is out of the question. That being said I had mine crack. I think the aluminum housing is a poor idea. That being said my 2577 has a reverser and It has cost me a lot of downtime over the years and I probably have used it about three times. I have thought about removing it as it seems like I could reverse it with the wrench and it would be waaaay cheaper. Quote Link to comment Share on other sites More sharing options...
axial_al Posted October 15, 2022 Share Posted October 15, 2022 Had one crack on my 2366. Later combines had an accumulator device to cushion the hydraulic shock. You can retro-fit earlier combines. Quote Link to comment Share on other sites More sharing options...
IHC5488 Posted October 16, 2022 Author Share Posted October 16, 2022 I am just having a hard time thinking that aluminum valve block cracked. I did find another one to put on the combine and we are back up and running again. In the meantime, also ordered a accumulater kit for the reverser. I just figured if the o-rings went out on the block or were trashed, I could rebuild it for a spare. Quote Link to comment Share on other sites More sharing options...
