Wesd Posted October 14, 2022 Share Posted October 14, 2022 I was doing some thinking and was wandering if I could install a 2 speed rearend in my 4070b instead of going through changing out the transmission and everything that goes with the installation. My truck has the spicer 1062-c 7 speed transmission and I was wandering if that would be a direction I could see about going with my truck. Quote Link to comment Share on other sites More sharing options...
dieselman Posted October 14, 2022 Share Posted October 14, 2022 2 speed usually reduces the ratio when in low range, not sure if you need more torque or more speed, hope this helps....dieselman. Quote Link to comment Share on other sites More sharing options...
td9inidaho Posted October 15, 2022 Share Posted October 15, 2022 I agree, typically what I have experienced, is 2 speeds where used with 5 speed tranny's, I'm sure others have more experience than I and will chime in on them Mark 1 Quote Link to comment Share on other sites More sharing options...
rbeckman Posted October 15, 2022 Share Posted October 15, 2022 We have a truck with 44,000lb Eaton double reduction rear axel, we converted them to 2 speeds giving 5.05 3.70 ratio. 1 Quote Link to comment Share on other sites More sharing options...
Wesd Posted October 15, 2022 Author Share Posted October 15, 2022 22 hours ago, dieselman said: 2 speed usually reduces the ratio when in low range, not sure if you need more torque or more speed, hope this helps....dieselman. Well I was wanting to put in a 10 speed transmission but just didn’t know how much of a hassle it would be finding all the linkages and if I need anything else for it so I thought maybe it would be better to just do a 2 speed rearend instead. Quote Link to comment Share on other sites More sharing options...
dieselman Posted October 15, 2022 Share Posted October 15, 2022 most wrecking yards here in western canada would have all you need, not sure if your 7 speed is direct drive in seventh or over drive. i think if your going for that major of a change might as well put a thirteen speed over drive in. 1 Quote Link to comment Share on other sites More sharing options...
hillman Posted November 6, 2022 Share Posted November 6, 2022 you could install a four speed auxiliary trans. a friend of mine put one in a square body Chev 1 ton 4 speed with a 454 LOL . This old guy is a master 1 Quote Link to comment Share on other sites More sharing options...
