Magnum tractor and Combine seat fabric
ThirdGenRed
Thanks guys. I had googled the fabric, but a lot choices that are close, I wanted to match the factory fabric. I thought maybe someone happened to know. I will contact Fehr Cab this week and see if they have it. If I find a source, I will post where you can get it.
Used to be able to get a new seet covering with the foam attached from Case. Pain to install but can be like new if installed correctly
