Which way this seal go?
andrewn269
Cup facing the pump, been fighting a new seal on a 560. It is too loose so when you push the pump in it gets caught on the recess and does not seat. Went back to the old style that you can barely move on the pipe and now everything is working.
"suction" is in the filter housing. Lip faces towards the pump. "suction" from the filter side will pull the seal lip tighter to the tube.
This type seal is to be pressed in housing. Then pump installed. Then tube inserted from filter side.
