hydraulic valve spool disassembly 1959 HUSCO valve body
BuckRun
Not familiar with that valve. I recognize the end opposite the linkage end as being a separate piece. I would assume a spring inside. In bottom picture. I can't see through the crud but I would expect a snapring between spool and plunger.
the spring is internal inside the bottom of the spool. That lower  piece (I call it the plunger) coming out of the bottom of the spool remains fixed with a spring pin to the valve body. The spool moves up or down under spring tension when you operate the lever for that particular cylinder. If I clamp the spool down I can push or pull that bottom piece about 1/2".
Real life exploded view of a spool from a 1959 HUSCO valve body
m/n 3256 on a Wain-Roy backhoe attachment on my '59 IH 340 Utility tractor.
I broke the spiral ring in 2 pieces. It was worn and some what difficult to remove. I used the tools shown. The rings are readily available.
Thx for everyone's input.
