Fuel Filter issues
806 man
Been fighting this for a year. Running Cat 3406E in 4 trucks. Fleet-gard Filters last 1700 -2000 miles. Local shop guy says problem is the fuel has less sulfur (EPA) so an addictive is added for lubrication this additive is getting cooked in the head and creating fine black particles which plug up the filter ( we have opened filters and found this )  the guy says the cure is don't shut off engine till it has cooled more so the fuel won't be cooked in the head which we have been doing by leaving trucks running when fueling up each day.  I have 2 fuel tanks a 15,000 for off road (no issues) and 6,000 on road which is where my issue is.
Any knowledge of this issue or suggestions.
Kind of odd that your off road trucks or equipment isn't getting as hot as your on road trucks. My understanding is it's the same fuel, just die added.
Are they the same distributors? Possibly different additives in the fuels you are getting if from different distributors.  Be curious to see how this ends up
Mark
8 hours ago, jass1660 said:
Sounds like you need the fuel additive from cummins that treats asphaltines, they are created when fuel gets too hot.
Do you have more info? Last Feb. my jobber added Valvtect to the loads never saw much difference. He did say I wasn't the only one with this issue.
Mark
Yes same jobber for both tanks. Run Deere equipment no issues there. I don’t think the trucks have fuel coolers
22 hours ago, Diesel Doctor said:
Wouldn't it be far easier to get rid of ultra low sulfur fuel.
All the issues are costing the consumer WAY to much.
What issues? If there were so many issues the online forums like this one, facebook, yt, and others would be absolutely CLOGGED with complaints for the last 12 years. Dead trucks would be littering the roadsides, so many the tow companies wouldn't be able to keep up, especially since their trucks died too. You hardly ever see anything in general, let alone anything that would be attributed to ULSD.
You can't tell me all these people are suffering in silence in this day and age.
When I see a ball of rust inside a diesel pump, due to the fuel, that causes an issue with me.
It ate away the timing mark on the governor weight retainer of the last pump I worked on.
It seized the pumping plungers on a pump that was overhauled less than six months ago.
It does not need to be as bad as Matt says to be an issue.
It is costing diesel owners a great deal of money now.
25 to 30 years ago many farmers around here were buying their first diesel pickup. Almost all of them said they would never have another gas pickup again. Now, many are saying they are done with diesel pickups due to high costs and reliability problems. I know it’s not all ULSD problems, but it’s one of many.
Yep. I went to a Cummins training class and they said its inside the injectors. Engine manufacturers have drastically increased the injection pressures to make the mist finer for better combustion to comply with emissions. This extreme pressure and heat causes a chemical reaction resulting in asphaltines. The small amount of fuel that goes back into the return line on the injectors carries the asphaltines back to the tank.
Well I haven't left any along the road, i try to proactive and change filters when 2500 miles. i see a few making 4500 miles so maybe things are starting to turn.
That be my case running diesel Pu since 1993. On my 5th and last one. I think the engines are ok it's the kind of use I do is what creates the problems. when I pass one down pu gets shorter trips. Shop to most fields are no more then a 8 mile drive so never get worked or hot much.
I've heard bio-diesel can be an issue.
On 9/24/2022 at 3:43 PM, ihrondiesel said:
Algae in your storage tank will cause the same issues, the filters are black but usually sort of slimy.  Maybe you have eliminated that possibility already.
I have a filter head which uses 2-10 micron Cim Tek filters which we change once or twice year, once the fuel is in the truck the problems start.
Been too busy changing injection pumps to be online complaining....
We have spent probably around 3X the money and time for maintenance along with increased prevention costs from more fuel additives since ULSD has shown up here. Done way more injection pumps since the lubrication is almost nill compared to with sulfur. We along with everyone else farming in the area have also had to add sulfur as a source of fertilizer since the change
On 9/25/2022 at 10:34 AM, JaredT said:
Our mechanic says fleet gaurd filters create a lot of problems with Cat engines. He says only Napa, Cat or Wix filters on Cat engines.
Ok, I bought 6 Cat filters, see what happens.
Same mechanic also says to put automatic trans fluid in your fuel periodically to add lubrication to the ulsf deisel fuel. He doesnt have near the trouble with injectors in Duramax as most other locals do. I dont know if it help, but he has had good results.
Don’t do that in any emissions engine with dpf or you will pay big time.
