acem Posted September 22, 2022 Share Posted September 22, 2022 My 826 is leaking hydraulic fluid from the transmission brake shaft. I replaced the o ring a few months ago. It slowed the leak but didn't stop it. I had the fluid drained to repair the pto so I replaced it again. This time I was very careful to install the o ring and shaft. It went together easily. But it still drips... It's not bad but it goes through a bucket every month or so. Any suggestions? Thx-Ace Quote Link to comment Share on other sites More sharing options...
England806 Posted September 22, 2022 Share Posted September 22, 2022 My 806 did this. I managed to find a slightly thicker o ring. Cured the problem. Another “fix” I use is wrap a little ptfe tape where the o ring seats in the groove in the shaft. It can be done on the outside groove o rings fit in but much more tricky. So far it’s worked every time. Cheap as well! 1 Quote Link to comment Share on other sites More sharing options...
hobbyfarm Posted September 23, 2022 Share Posted September 23, 2022 22 hours ago, acem said: My 826 is leaking hydraulic fluid from the transmission brake shaft. I replaced the o ring a few months ago. It slowed the leak but didn't stop it. I had the fluid drained to repair the pto so I replaced it again. This time I was very careful to install the o ring and shaft. It went together easily. But it still drips... It's not bad but it goes through a bucket every month or so. Any suggestions? Thx-Ace A bucket is $124 here. That hurts. Quote Link to comment Share on other sites More sharing options...
axial_al Posted September 23, 2022 Share Posted September 23, 2022 Are you sure the casting doesn’t have a hairline crack in it? Good luck. 1 Quote Link to comment Share on other sites More sharing options...
acem Posted September 23, 2022 Author Share Posted September 23, 2022 1 hour ago, axial_al said: Are you sure the casting doesn’t have a hairline crack in it? Good luck. Never thought bout that. Thanks! Quote Link to comment Share on other sites More sharing options...
oleman Posted September 23, 2022 Share Posted September 23, 2022 I am losing hydraulic oil on the 464 but it appears to be the steering cylinder seal leaks when the steering is cycled. Quote Link to comment Share on other sites More sharing options...
