Absent Minded Farmer Posted September 21, 2022 Share Posted September 21, 2022 I ran across a part with an odd part number (387229R1) in my collection & the Depot returns it as a valve. They posted a pic of it too. Looks familiar.... just can't place what it goes to. Mike Quote Link to comment Share on other sites More sharing options...
nepoweshiekfarmalls Posted September 21, 2022 Share Posted September 21, 2022 Banjo bolt for hydraulic valves? Quote Link to comment Share on other sites More sharing options...
Jeff-C-IL Posted September 21, 2022 Share Posted September 21, 2022 That looks like the remote pressure regulator off any 06-86 series, the p/n will tell you the working pressure. Someone likely replaced it with a higher pressure unit. 4 Quote Link to comment Share on other sites More sharing options...
DT Fan Posted September 21, 2022 Share Posted September 21, 2022 2 hours ago, Jeff-C-IL said: That looks like the remote pressure regulator off any 06-86 series, the p/n will tell you the working pressure. Someone likely replaced it with a higher pressure unit. X-2. Quote Link to comment Share on other sites More sharing options...
ny bill o Posted September 22, 2022 Share Posted September 22, 2022 9 hours ago, Jeff-C-IL said: That looks like the remote pressure regulator off any 06-86 series, the p/n will tell you the working pressure. Someone likely replaced it with a higher pressure unit. my first reaction, too. My brother had to replace one on his 806 b/c the old relief valve wouldn't pick up the discbine. Quote Link to comment Share on other sites More sharing options...
TN Hillbilly Posted September 22, 2022 Share Posted September 22, 2022 On 9/21/2022 at 1:57 PM, DT Fan said: X-2. X3. Goes under the seat on the right hand side. 706, 806, probably lots of others. Quote Link to comment Share on other sites More sharing options...
DT Fan Posted September 23, 2022 Share Posted September 23, 2022 15 hours ago, TN Hillbilly said: X3. Goes under the seat on the right hand side. 706, 806, probably lots of others. Up through '66 series at least. Had to upgrade this on my 1066 so it would fold up the cyclo. Quote Link to comment Share on other sites More sharing options...
Jeff-C-IL Posted September 23, 2022 Share Posted September 23, 2022 THese were on all "large frame" from the '06 thru the '86 series with OC hydraulics, not sure what they did after they went to PFC. We replaced the one in the 1066 with the '86 series one for enough power for the big Westendorf loader. Then years later later I put the original 1066 one in the 806 to lift the corn planter full of seed and 28%. The original 806 one may still be laying on a shelf somewhere.... Quote Link to comment Share on other sites More sharing options...
Farmall Doctor Posted September 23, 2022 Share Posted September 23, 2022 They also fit Doncaster tractors like the 574 right up through CX90 Quote Link to comment Share on other sites More sharing options...
sandhiller Posted September 23, 2022 Share Posted September 23, 2022 On 9/21/2022 at 9:32 AM, Jeff-C-IL said: That looks like the remote pressure regulator off any 06-86 series, the p/n will tell you the working pressure. Someone likely replaced it with a higher pressure unit. Had to replace mine on the 966 to raise the tailgate on the new baler. Wow, what a difference! Quote Link to comment Share on other sites More sharing options...
jd4440 Posted September 24, 2022 Share Posted September 24, 2022 It looks like a relief valve, but part number 387229R91 calls it an anti-cavitation valve for backhoe attachment Quote Link to comment Share on other sites More sharing options...
