IH 1460 Fan Switch
Resistor built into the switch?
On 9/18/2022 at 11:11 AM, IHC_1470 said:
Do you have power at the switch and is it switching between output terminals when you move it back and forth? If so is the power getting to the motor?
Had time to check this evening with test light.
Power at switch.  Then put switch back on and have power at motor.  Just put new motor on.  Will have to look at it some more.
