KY2674 Posted September 5, 2022 Share Posted September 5, 2022 Anyone know where to find a front crank seal? Haven't taken apart yet but is slinging a lot of oil from behind the PTO clutch. Everything on the internet says not available. Quote Link to comment Share on other sites More sharing options...
515Dave Posted September 5, 2022 Share Posted September 5, 2022 That’s the rear seal. Engines in cubs are installed backwards. It’s Kohler Part # KH-X-583-5 and should be available pretty much anywhere. 1 Quote Link to comment Share on other sites More sharing options...
KY2674 Posted September 6, 2022 Author Share Posted September 6, 2022 2 hours ago, 515Dave said: That’s the rear seal. Engines in cubs are installed backwards. It’s Kohler Part # KH-X-583-5 and should be available pretty much anywhere. Thanks. Did a little more searching and figured that out. 1 Quote Link to comment Share on other sites More sharing options...
Mr. Plow Posted September 6, 2022 Share Posted September 6, 2022 Just did one...... Clean the seal bore with a cotton swab and alcohol then right before you install the seal (5/32" seat depth) put a bead of gel control super glue on the outer circumference of the seal (glue it into the bore). 90% of the seal failures on Kohler twins are because they push the seal out of the bore. Gluing them in helps...a lot! The one that went south on mine was actually making a chugging noise at idle from sliding back and forth in the bore. Don't forget to reset the air gap on the PTO clutch.... .010"-.012" 1 1 Quote Link to comment Share on other sites More sharing options...
Mr. Plow Posted September 6, 2022 Share Posted September 6, 2022 ...and I have a flywheel side crank seal to replace on an M18 too......just started slinging oil last mowing. That one sucks.....pull engine and flywheel...clean up all of the tins...... At least it isn't pushed all the way out yet (not a big enough mess!!!) 1 Quote Link to comment Share on other sites More sharing options...
Mr. Plow Posted September 6, 2022 Share Posted September 6, 2022 2 1 Quote Link to comment Share on other sites More sharing options...
fbh31118 Posted September 10, 2022 Share Posted September 10, 2022 On 9/5/2022 at 11:10 PM, Mr. Plow said: ...and I have a flywheel side crank seal to replace on an M18 too......just started slinging oil last mowing. That one sucks.....pull engine and flywheel...clean up all of the tins...... At least it isn't pushed all the way out yet (not a big enough mess!!!) This is the seal that failed in Tammies tractor the first time we put a plow on it. I set the plow up and she made one pass before it blew out on the headland.😁😆 Quote Link to comment Share on other sites More sharing options...
