fbh31118 Posted September 5, 2022 Share Posted September 5, 2022 Got the wifes 782 our for a bath that it needed desperately and pulled the motor. There is a leak coming from some where, so the block was caked with dirt pretty bad. Also, fuel pump diaphram was failing and leaking into the block so a new fuel pump went in. Started with removing the tin and repaired the starter, which had gotten loose, with a few washers and lock nuts. Got a roll of gasket paper and cut out some new gaskets for the valve covers, which is where I hope the leaks were coming from. Hoping to get the oil changed today and give it a test start to see what happens. We went completely through this motor many years ago as our first 'learning' experience with engine rebuilding. Pretty sure I had this motor apart 3 times to get is close to being right.😉😆 The plus side was taking the plugs out of the engine yesterday and seeing that they were completely clean. It appears to have been running well other than the external oil leak and fuel pump failure. I know, I should go electric on the pump but the mechanical has worked so well for so long. One of the tires has a bad valve stem, which will be headed to the tire shop for a new stem and reload of beat juice, now that I think about it........ Hope to have it up and running with fresh fluids this next weekend. The hydro fluid hasn't been changed in years but honestly it might have 20 hours on it at the most. I haven't bought filters for the hydro in forever, hope Cub still makes them.😁 5 Quote Link to comment Share on other sites More sharing options...
fbh31118 Posted September 11, 2022 Author Share Posted September 11, 2022 A little update video. Great running little engine. 2 Quote Link to comment Share on other sites More sharing options...
Alan Dinan Posted September 11, 2022 Share Posted September 11, 2022 Will you be able to mount the external filter somewhere so that the side cover goes on? Quote Link to comment Share on other sites More sharing options...
drglinski Posted September 11, 2022 Share Posted September 11, 2022 1 hour ago, Alan Dinan said: Will you be able to mount the external filter somewhere so that the side cover goes on? That looks like something I'd inadvertently kick off. Quote Link to comment Share on other sites More sharing options...
Mr. Plow Posted September 12, 2022 Share Posted September 12, 2022 On 9/11/2022 at 1:57 PM, Alan Dinan said: Will you be able to mount the external filter somewhere so that the side cover goes on? I bolts to the firewall right under the throttle/choke cables on an angle. Clears the side sheet nicely. 2 Quote Link to comment Share on other sites More sharing options...
Mr. Plow Posted September 12, 2022 Share Posted September 12, 2022 On 9/11/2022 at 11:26 AM, fbh31118 said: A little update video. Great running little engine. She sounds nice and smooth!!!! 1 Quote Link to comment Share on other sites More sharing options...
fbh31118 Posted September 13, 2022 Author Share Posted September 13, 2022 15 minutes ago, Mr. Plow said: She sounds nice and smooth!!!! It really does, had it apart 3 times to get it right though. Several things I would do differently after getting all the way through it now. Quote Link to comment Share on other sites More sharing options...
Mr. Plow Posted September 13, 2022 Share Posted September 13, 2022 I like the boxer twins, but they do take a little bit of finesse to get back together leak free. M20 is a HORSE on the plow. 1 Quote Link to comment Share on other sites More sharing options...
Mr. Plow Posted September 18, 2022 Share Posted September 18, 2022 Have one torn down right now (case leak...I think). Starts going back together tomorrow 😀 2 Quote Link to comment Share on other sites More sharing options...
fbh31118 Posted September 18, 2022 Author Share Posted September 18, 2022 18 hours ago, Mr. Plow said: Have one torn down right now (case leak...I think). Starts going back together tomorrow 😀 Nice! I'm hoping I got all of ours taken care of on this go around. Quote Link to comment Share on other sites More sharing options...
