Water Pump for C200 engine in 574
red35x
I found a bare block which is at the machine shop getting bored. so now I am being a little proactive in getting all things lined up to reassemble engine and put back in the 574. One thing I noticed is that the water pump is a little wobbly. So does anyone have a good used water pump for a c200 engine. there were engine models c157, c175 and C200 that all used the same. OR i checked CNH parts and they do not list a rebuild kit. The part # is400677r92 for the water pump.
May be better off just finding new or rebuilt one online as most around the $ 120 range.
Any advise....THANKS
  • 4 months later...
Many of those water pumps used the same rebuild kit with the casting being the difference between engines.
The JD 3010 gas water pump kit fit a lot of water pumps including Chevrolet.
I am not saying this kit will fit your C200.
I am saying you can probably find the bearing and seal if you get the old out so you can measure.
Then again, look at this new one for $100 bill:
https://www.ebay.com/itm/184571298183?epid=8042419689&hash=item2af94e8187:g:mEYAAOSwbPtggTxn:sc:ShippingMethodStandard!57201!US!-1&amdata=enc%3AAQAHAAAA4HzredVSrK0uu2Vcd7WHXWxxtHpIhWl43gf62whOJg0lVpgMTH6fHwDw%2F2RP2XxOd%2Fc%2FeuoqdnetE%2BPQW%2FgPPyQlO7qyp2PC6V6J1Sve412gW1iQfcwrWWgqG%2B4S47MP%2Fx%2FtCx9%2BUzImOdA51xjKquWpP6%2B0L8On%2FvQu3Yl5LJPtB8LaVYyR9rs7M6cHVSf%2FrdviZZ1n87YrT7zwakEITf4letAwhls9SxY0qtfrD8RPEEsBeqqLKQ9AVf1j1FCNVY5eRaujvKwIYpy3R4Dk169YYADtY3xR%2FH1wdGYm4mfV|tkp%3ABk9SR7LAs6ayYQ
