Power of Red Posted August 20, 2022 Share Posted August 20, 2022 Hi Guys this one is for the pullers and charge system experts. what are you guys using as a light weight battery ? How small in crank amps can i go on my w6/farmall M starter. will my 100a ac delco alternator fry a U1L lawn and garden battery? i think 350ca will be sufficient for a machine that will not need to start in cold weather and has only two lights that are most likely getting deleted. Al Quote Link to comment Share on other sites More sharing options...
Diesel Doctor Posted August 20, 2022 Share Posted August 20, 2022 The usual thought is, "You can't go to big." So never tried to go to small. Try one and give a report. You may want to throw a blanket or a bucket over the battery, just for safety sake, before you hit the button? 1 Quote Link to comment Share on other sites More sharing options...
dannyredfan Posted August 20, 2022 Share Posted August 20, 2022 I want to ask. Why a 100amp alt. ? need it for ignition system? whould a 100amp pull harder? Probably not enough to make a difference? and is 5-10# of battery going to make much difference? I thought most alternators where 35-60 amp. when I was getting the ac. fixed on my tractor, I had to put a 100amp on to keep up with the blower and lights. Just wandering just random thoughts from a guy that doesn’t know. 1 Quote Link to comment Share on other sites More sharing options...
hillman Posted August 20, 2022 Share Posted August 20, 2022 2 hours ago, Power of Red said: Hi Guys this one is for the pullers and charge system experts. what are you guys using as a light weight battery ? How small in crank amps can i go on my w6/farmall M starter. will my 100a ac delco alternator fry a U1L lawn and garden battery? i think 350ca will be sufficient for a machine that will not need to start in cold weather and has only two lights that are most likely getting deleted. Al if the regulator works properly there is no reason for a battery of any size to be fried by a large alternator. are you so close to your target weight that you cannot add a few #s for a decent battery 58 minutes ago, dannyredfan said: I want to ask. Why a 100amp alt. ? need it for ignition system? whould a 100amp pull harder? Probably not enough to make a difference? and is 5-10# of battery going to make much difference? I thought most alternators where 35-60 amp. when I was getting the ac. fixed on my tractor, I had to put a 100amp on to keep up with the blower and lights. Just wandering just random thoughts from a guy that doesn’t know. I cannot speak to all alternators but most don't make any weight difference going to a higher output ie, a Delco 10si is increased by changing the stator ( my guess is that's what he is using)- no real weight difference Quote Link to comment Share on other sites More sharing options...
Mudfly Posted August 20, 2022 Share Posted August 20, 2022 Delete the battery and use a jump pack to start it. Or put a motorcycle battery in it and supplement it with a jump pack as needed. And then you could delete the gen/alternator also. 1 Quote Link to comment Share on other sites More sharing options...
hillman Posted August 20, 2022 Share Posted August 20, 2022 2 hours ago, dannyredfan said: I want to ask. Why a 100amp alt. ? need it for ignition system? whould a 100amp pull harder? Probably not enough to make a difference? and is 5-10# of battery going to make much difference? I thought most alternators where 35-60 amp. when I was getting the ac. fixed on my tractor, I had to put a 100amp on to keep up with the blower and lights. Just wandering just random thoughts from a guy that doesn’t know. I got curious on your HP question,. "An alternator typically takes about 1 HP (horse power) for every 25 amps of power generated. So, a 100 amp alternator will require about 4 HP at full output. Most alternators do not operate at full output for very long." https://alternatorparts.com/how-much-horse-power-does-an-alternator-make.html#:~:text=An alternator typically takes about 1 HP (horse,not operate at full output for very long. DD 's idea of covering the little battery is a good one IMHO I have in my plans to build something similar Al. I would chop as much cast out of the tub as possible and make a lighter front axle bracket from steel while eliminating the leaf spring I have a set of spoke hubs here for a W6 if you want to make the trip Quote Link to comment Share on other sites More sharing options...
MinnesotaFarmall Posted August 20, 2022 Share Posted August 20, 2022 Probably running high output alternator for electric fan. Quote Link to comment Share on other sites More sharing options...
Diesel Doctor Posted August 20, 2022 Share Posted August 20, 2022 The alternator weight should remain close for all. 10DN, 10SI and newer Delco's. The more amperage power output means more HP to do so. Nothing is free. You do need power to excite the alternator to make it charge so you do need some sort of a battery. Try a very small one and use a jump pack to get it started. Save a few pounds here and there and all of a sudden you are talking serious weight. I can smell a test coming to see what works. Quote Link to comment Share on other sites More sharing options...
oleman Posted August 20, 2022 Share Posted August 20, 2022 Lithium race car battery, if weight is a serious issue. It can give good AH rating and light weight. Don't look at the cost until after you lose! Quote Link to comment Share on other sites More sharing options...
Power of Red Posted August 20, 2022 Author Share Posted August 20, 2022 I agree 100a is way overkill, the alt was free and lighter than the 10si it replaced. So thats why so big. I am running electronic ignition so the battery is needed. If i jump to a hotter class where electric fans are permitted, i have the juice to run it. About the weight, placable weight is a huge advantage in the hot stock classes i run. The 5mph is killer so making sure i can hook good to the track is important. I can only dream of hitting 4500#... but i killed that dream this week. I am picking up two sets of original wheel weights next week. We dont have a 5000# class so i am aiming to make 5500 with 580# in the wheels and a bit of wiggle room for placable weight. I dont want to have to take those 145# s.o.b off to make it into the lighter class. The next class up is 6500# i know i am gaining 5-10# with a smaller battery but every pound counts in this game. Call me crazy! But thats what they call pulling fever lol. Quote Link to comment Share on other sites More sharing options...
twood1954 Posted August 20, 2022 Share Posted August 20, 2022 I would suggest eliminating the alternator and use weight saving to run a bigger battery. Alternators take HP to turn. I don't run one and I have electric fan, water pump and rearend pump that I run on mine on the 12v side. I have 3 batteries to supply the 36 volts start. I have never had single 12-volt battery run dead after up to two pulls on same night. Just make sure they are charged up. On side note use battery weight to your advance. If you light on front move it there etc. 1 Quote Link to comment Share on other sites More sharing options...
Farmall Doctor Posted August 20, 2022 Share Posted August 20, 2022 Put a magneto on it, remove the battery and alternator, and be really cool by crank starting it! 6 Quote Link to comment Share on other sites More sharing options...
hillman Posted August 21, 2022 Share Posted August 21, 2022 1 hour ago, Farmall Doctor said: Put a magneto on it, remove the battery and alternator, and be really cool by crank starting it! I was going to suggest it but thought if he stalled it hooking and had trouble starting it on the track the JD boys would have a hey day Quote Link to comment Share on other sites More sharing options...
Farmall Doctor Posted August 21, 2022 Share Posted August 21, 2022 Do they have green and yellow tractors in Quebec? They didn’t sell hardly at all in my area… we had much better choices. 3 Quote Link to comment Share on other sites More sharing options...
560Dennis Posted August 22, 2022 Share Posted August 22, 2022 12 volt battery pack for distributor ignition Quote Link to comment Share on other sites More sharing options...
