560 tractor Posted August 8, 2022 Share Posted August 8, 2022 i'm trying see what the foot valve does and how it works. what i'm wondering if there is any adjustment on it. so if anyone can let me know. Quote Link to comment Share on other sites More sharing options...
VacDaddyt Posted August 10, 2022 Share Posted August 10, 2022 Well some one may need to correct this but; When you steer the collar of the actuator moves a tiny amount forwards or back based on the direction you are steering. When it moves a channel(think valve) opens up letting fluid move pressurizing the correct side to assist in the steering. If the last knuckle down by the valve does not let the shaft move in and out a little it will defeat the steering assist. If some one took it apart the little stub shaft that goes up into the valve can be in the wrong place. Also I have seen some one weld the last knuckle on and then it will not work also. Splines have been stripped out etc. don't have the book with me right now. Quote Link to comment Share on other sites More sharing options...
snoshoe Posted August 10, 2022 Share Posted August 10, 2022 Most common thing I found was to move joint at bellhousing up shaft a bit. That pulled horizontal shaft back a bit and allowed valve to work. Yes there are adjustments but I would need manual. Quote Link to comment Share on other sites More sharing options...
560 tractor Posted August 11, 2022 Author Share Posted August 11, 2022 thank you i will try these Quote Link to comment Share on other sites More sharing options...
ksfarmdude Posted August 11, 2022 Share Posted August 11, 2022 Power steering on the 60's series tractors was minimal at best 1 Quote Link to comment Share on other sites More sharing options...
Farmall Doctor Posted August 11, 2022 Share Posted August 11, 2022 21 hours ago, snoshoe said: Most common thing I found was to move joint at bellhousing up shaft a bit. That pulled horizontal shaft back a bit and allowed valve to work. Yes there are adjustments but I would need manual. Interesting.... my 560 steers well, but always pulls to the right a bit. I'll have to check out the shaft and mounts. Quote Link to comment Share on other sites More sharing options...
