Torque Posted August 1, 2022 Share Posted August 1, 2022 Read online to back out spring and set idle 50 rpm low of what you want and then turn in bumper to raise rpm. Is this the correct procedure? Adjusted this a few years ago to stop surging but it is back to it, maybe something is worn out? Quote Link to comment Share on other sites More sharing options...
CIHTECH Posted August 1, 2022 Share Posted August 1, 2022 The Cummins bulletin states as much as 150 rpm if needed. Is your bumper spring soft? If so I would recommend a heavy duty one (can hardly squeeze with your thumb) Quote Link to comment Share on other sites More sharing options...
