Couple of old pictures, of interest........"Red " related !!......more pictures added...and more again
Posted
TD9B's had the dozer lift cylinders like in the picture, but I thought they were yellow when the TD9B came out. I have a TD9B original sales brochure and it doesn't show a hydraulic tank on the right side of the fuel tank. 92 series? but I thought they had the old style lift for the dozer?
DWF
Posted
On 3/6/2026 at 5:43 PM, Pukeko said:
I think Allis is referring  to the top  left pic of the black and white really fuzzy ones. ( not the red 9B in the colored pics.)
Peter...the    'fuzzy '' ones are Michael Farrington' s   open station TD 20.....caught in that shingle slide up the Graham Valley, I really had no idea what in those fuzzy pictures but  ''Alan B''   who actually witnessed this near disaster confirmed that fact....
Posted
DWF
There were "Red" painted 9B's   down under....IH New Zealand   may well have been the culprit  there....and NZ made  blade gear for imported track machines ....which often differed from American manufacturers
Posted
DWF
DWF, you are correct in the location of the dozer lift cylinder location, the earlier TD9-92 series used the Bucyrus-erie blade from the factory. The hydraulic tank on that red TD9B was an optional attachment for the increased hydraulic pump system (33 gpm). Here is a picture of our 9B with the large hydraulic tank with a 3 spool valve, this is an Ag tractor which has the larger fuel tank (44 gallons) Also a picture of a TD9-92 with the Bucyrus-erie blade. The picture of the 9B with the blade is an industrial power shift, not mine.
Posted
And different blade gear here in Kanada too, Mike. I have 2 sets of over the track lift arms/cylinders/blades that were made by Smiths known as Northern Machine Works in Bathurst, New Brunswick. Very similar to Bucyrus-Erie setups in the States.
Posted
I had a TD-9B back in the 70's. It was a direct drive with a DT-282 turbo engine. It had the angle blade like in the one above, I had a TD-9 92 series with a Drott loader too. Still have a Dresser TD-9H, It is a 98 model with a little over 3000 hours. I purchased it in 2003 with around 1900 hours.
DWF
Posted
I was referring  to the top  left pic ,black and white .I also think it is a TD14.I figured the TD20 was Farringtons  machine .I also have a pic of it somewhere.
Posted
I bought this TD15B from a dealer in New Hampshire 15 or 20 years ago as a parts machine for my TD15 (the motor was stuck on the U.S. one). The Canadian customs office at the border refused entry for a bit of dirt still on the tracks. So my hired float turned around, went back into town and found a shop to pressure washer it off.  Cost me a few extra bucks, of course.
  • Like 7
Posted
I had an HD6, it didn't look like that.
DWF
Posted
On 3/17/2026 at 8:32 PM, jeeper61 said:
Mack CL700 6x6 sporting a golden dog
You ought to be more careful, Jeeper! I dont know if Mike Newman's old heart can take such a sight, or not!
Good thing there's not a lever action carbine leanin against that front tire!
  • Haha 3
Posted
....it was ok  TN hillbilly......saw it early morning, just after taking my BP  pill.....(I was sitting down  also....;))
Posted
3 minutes ago, jeeper61 said:
Small load of pulpwood
I'm kinda guessing that there was no driving on public roads/highways with this load @jeeper61?  😉
Posted
Not sure where that was taken
In Maine up in the North Woods it's all private timber company roads they haul 250K+ over height stuff to the mill
Posted
Truck probably couldn't handle much more weight. 427 V-8. Makes sense its in Maine. I think they had some private roads up here too for bigger logging companies and contractors. No speed limits and two way radios.
Posted
For medical tissue they need to use virgin pulp no recycled paper content.
There is a mill for medical tissue near my camp in Baileyville, ME.
So there is a lot of pulpwood logging in the area, they cut off most wood lots every 20 years.
Drives the tree huggers nuts and the wardens have to patrol active logging sites to prevent vandalism by activists.
With modern equipment and better logging roads they load out semis with longer lengths.
You don't see much short wood anymore.
Posted
Some good footage of Herm Hobi from Aberdeen Washington.
Using CAT Dozers with logging arches
1937 D model IH trucks getting the big logs out
Posted
#2 Daughter  operates various  equipment....in Western Australia
Komatsu bucket holds 50 tons...........
  • Like 5
Posted
That is a big one
Interesting tire sock on the front
