Couple of old pictures, of interest........"Red " related !!......more pictures added...and more again
On 8/11/2022 at 10:29 PM, mike newman said:
.....a lot of work ahead of your  TD9......@td9bcf180  !!!!
Yes, for sure, Mike. But the last pic I posted was from 4 years ago in the shop. I have it down to the frame and tracks and ready to pull steering clutches (both seized) and check final drives. Complete rebuild.  I have a second machine for parts.
And I see why final drives blow up with that contraption swinging overhead!   Yikes!
Still favour that AR174. Neat grille. Solid looking beast.
You get my mail?
....If you are into working up some good , rolling farmland...there is nothing better than a set of tracks under you....unhampered by some of the hideous blade setups...and with an open station ....for the ''command centre ''
Working up old pasture, with a good moisture content...equates with no dust...and throw in a few hills....That is really living  !!!
...even if its an HD6...pulling, I believe, a disc plough........
  • Like 9
If it weren't for the grass I'd say that photo was at the landfill with all the winged sea rats flying about
Thx for sharing the photos Mike
  • 3 weeks later...
....a Fiat  /Allis   AD8   crawler.......In actual fact a 'Fiat " ....slightly bigger than a D4    C /D...and seriously good machines..Only a handfull   arrived in NZ...Photo taken on a back country farm, in Marlborough    South Island  NZ
  • Like 6
https://tractors.fandom.com/wiki/Fiat-Allis lists  AD/BD line as AD4, 5, 7, 9, 10, 12, 14, 20.  but misses 8 for some reason.  BD models have a straight tilt blade.  Some 20's came in here from South Korea with Cummins (855 IIRC) engines - I'm guessing their military used that engine.  As did parts for Allis HD 16's so Allis likely had a military connection there earlier.
We have a BD 10 which we got second hand and it is still a very useful dozer for ranch work (about 1975 vintage) and still with reasonable parts availability.
14 hours ago, Ian Beale said:
Ian...the ''8''  is in fact shown on that link...but with no detail....I could be in error with regard to the "'AD''  prefix..but the one we worked with locally, years gone, was always referred to as an "AD8''......so I intend to go down to Rock Station  soon ...and I now know where that pictured tractor lives...so I will get up close and personal  and ''check her out ''
AD models had an angle and manual tilt blade, BD were straight (actually more semi-U) with hydraulic tilt.  Officially both AD and BD went out of use about the 10B era going on the workshop manual we have.
  • 2 months later...
...just got a new ''thingy''  finally to convert 35 mm slides into  the ''computer format ''...all red stuff !!!......nothing very dramatic
T20  Fordson Super Major
Hough Loader
TD20 (useing the river for a road..as we did back then...)
TD25
BTD6
BTD6   ..probably took me longer to hook all that  stuff  up..than to drill the paddock
British 634   with trailing    back hoe   360 degree swing
TD24  backing up in the river
  • Thanks 3
  • mike newman changed the title to Couple of old pictures, of interest........"Red " related !!......more pictures added...and more again
I never was lucky enough to operate a TD25 but that sure is one powerful looking dozer. (petrol/gasoline start and switchover to diesel?) Thanks for posting these pics.
..no worries there....sadly the very old  colour slides have sort of darkened a lot over the last fifty plus years....
What model year was the TD25, Mike?  Did it start on petrol, before switching over to diesel?
...Sorry !!.....it was a direct start on diesel....      817 engine  , I guess ??.....about mid sixties  as I recall....I would have been in my early twenties.....thus the excitement factor would have way exceeded the  ''specification''   detail....
No apology needed, Mike!   The TD25 you show in the picture is red so I thought maybe late 50's and maybe gas start.  I grew up on TD9's, then TD15's and run a few Cat D6's along the way plus an AC. But a TD25 must have been a thrill ride for power as you noted. Thanks for posting all these pics.
Hi Mike , I'm just catching up on this thread. The great old memories (pictures) keep coming.  Old pictures are like old people; even when clarity isn't perfect we are looking at and listening to is history, the best available sample is always museum worthy.  This place this site is a museum with a section for you . Thank you!
I've always wonder about the dozer in my avatar, it's my Dad, probably late 40's and fairly sure it's a new dozer but don't know what model.  Story goes; my uncle and dad go to Peoria(some may understand the significance of that) bout 60miles away, again late 40's looking for a dozer, dad was back from the war and my uncle had a little money, ended up at an IH dealer looking at one new on the showroom floor. Now these 2 hicks from the sticks, more then likely dressed the part and after kicking tires so to speak flagged down a salesman. I can only imagine what he thought but dad said for the most part talked down to them and when my uncle asked how much he scoffed a little and blasted out $7000. Well, my uncle who is old school swede thought about it for a bit, grabbed the straps of his bibs and asked if they deliver.....Anybody got an idea of what model is in the pic? thinking it's an older 18 but I have no idea.
It looks 18 in size, single exhaust would be last one 182 series but the air intake on the dash doesn't match and is early style, looks a bit big for a 14?
Can you zoom in on your original photo to see the numbers under "TD" on side of fuel tank?  Could be a 9 but more likely a 14, in my opinion. 5 bottom rollers were not standard on TD9's.  I'm sticking with TD14.
I'd say that is a good call, the cable super structure makes it appear a bit larger than if stripped, possibly another dozer behind the scraper?
Most people concur it's either a 14 or 18, and yes that's another dozer in the background. This was waaaay before my time, I started in 73 on an 18A. Every cable unit I've ever run had the same lever configuration just like this. I've tried to zoom in but just blurs out. I'm going to venture back in the day that blades were added by the dealer, seen to many different style cable runs to be factory, dad always called these headache bars, in my time they were mounted to the fenders. Didn't 18's have 6 bottom rollers?
