1066 farmall tractor draft sensing leaking right side
Had this tractor for years and ran like a champ noticed it’s been using hydraulic fluid a lot lately got to looking and done my research I believe the draft sensing is leaking if you look at the back of the tractor it is on the right side and tips and pointers on how to change this and fix it would help thanks!
If i remember correctly that side has to come comepletely out shaft and all PTO out to get to Draft sense arm .More than likely bushing is worn which in turn got the o ring.Long story short you will have both sides apart to get to the right side .Perhaps posting in Technical Forum will catch some of the sharper ones on here if not pm me i help you with it .
