bitty Posted July 21, 2022 Share Posted July 21, 2022 Does anyone have a wide front on a C they can get a decent drawing for the flat stock axle stops that bolt under the radiator. I have to make a set for the axle I have. Thickness, width, length, bolt pattern and the approximate radius of the rounded front end. Quote Link to comment Share on other sites More sharing options...
12_Guy Posted July 21, 2022 Share Posted July 21, 2022 I don't but a friend does. If nobody else can help let me know. I could go over to his place and measure his. Hopefully someone else has one closer. Quote Link to comment Share on other sites More sharing options...
Dave Downs Posted July 21, 2022 Share Posted July 21, 2022 I’ve got them, bought wide front for narrow front C, had them made. Will be back with pictures and measurements soon…… 1 Quote Link to comment Share on other sites More sharing options...
Dave Downs Posted July 21, 2022 Share Posted July 21, 2022 12” x 1-3/4” x 3/4” bolts look to be 2” center to center, back hole 1/2” in your on your own for hole diameter!!! 2 Quote Link to comment Share on other sites More sharing options...
Dave Downs Posted July 21, 2022 Share Posted July 21, 2022 Just noticed you wanted radius for front of stop, will check other C, I think that one has factory stops. I’ll pull one off for better measurements, might not happen until tomorrow. And I think stock is slightly smaller. Quote Link to comment Share on other sites More sharing options...
bitty Posted July 21, 2022 Author Share Posted July 21, 2022 11 minutes ago, Dave Downs said: Just noticed you wanted radius for front of stop, will check other C, I think that one has factory stops. I’ll pull one off for better measurements, might not happen until tomorrow. And I think stock is slightly smaller. It doesn't need to be taken off. Tape measure estimate is good enough Quote Link to comment Share on other sites More sharing options...
Dave Downs Posted July 22, 2022 Share Posted July 22, 2022 Here’s the IH part 12”x2”x5/8” 1/2” holes 2” center to center radius on both ends 1-7/8” 2 Quote Link to comment Share on other sites More sharing options...
TN Hillbilly Posted July 22, 2022 Share Posted July 22, 2022 You just can't beat the folks on the Red Power forum! 5 Quote Link to comment Share on other sites More sharing options...
bitty Posted July 22, 2022 Author Share Posted July 22, 2022 7 minutes ago, TN Hillbilly said: You just can't beat the folks on the Red Power forum! X2 Quote Link to comment Share on other sites More sharing options...
Rusty shackleford Posted July 23, 2022 Share Posted July 23, 2022 Will always say the 240 wide front looks way better on a c to 230 1 Quote Link to comment Share on other sites More sharing options...
bitty Posted July 23, 2022 Author Share Posted July 23, 2022 5 minutes ago, Rusty shackleford said: Will always say the 240 wide front looks way better on a c to 230 If that ever goes up for adoption lemme know... I have a few 230's that want more company 😁 1 1 Quote Link to comment Share on other sites More sharing options...
