Dell Posted July 17, 2022 Share Posted July 17, 2022 So I got my m running the only issue is when I pull back on the throttle quickly it stumbles then goes wide open . If I do it slowly it fine. It has a rebuilt clean carb new intake and gasket. Electronic ignition, new plugs . Compression is good , valve all adjust . I’m think I did adjust the carb rich or governor is sticking any thought on how to trouble shoot this. Quote Link to comment Share on other sites More sharing options...
DWV Posted July 17, 2022 Share Posted July 17, 2022 Could be not rich enough. How far is the adjustment screw that points to front of tractor screwed out? Try opening it up some or try with choke on some and see if it temporary helps. Quote Link to comment Share on other sites More sharing options...
Matt Kirsch Posted July 18, 2022 Share Posted July 18, 2022 Timing. With the letter series you gotta tune em by ear. Set it so it sounds best at idle then pin the throttle wide open quick. If it stumbles go back to idle and tweak the timing a tiny bit. If it gets worse go the other way. Keep tweaking until it doesnt stumble or stumbling is minimal. Quote Link to comment Share on other sites More sharing options...
Dell Posted July 18, 2022 Author Share Posted July 18, 2022 wh how should the idle screw be adjusted just so it idle smooth/ Quote Link to comment Share on other sites More sharing options...
