Missouri Mule Posted July 18, 2022 Share Posted July 18, 2022 11 hours ago, KyIH said: Would a cheaper, say alliance radial be a better option over a bias Firestone? Friend of mine put some 18.4-34 alliance radials on an 8240 ford 2wd. They look good, and go good. However, he is probably about 8 years in and the sidewalls are cracking out so bad around the bead I'm not sure they will see 10 year mark. On a light tractor with very few hours, no fluid. Tread is still 90% I used to have pictures in my phone, dont no more. I've got tires that are 40 years old that arent splitting out that bad. Quote Link to comment Share on other sites More sharing options...
KyIH Posted July 18, 2022 Author Share Posted July 18, 2022 That’s a very good point. I don’t want a tire that rots away before the tread is worn down. Quote Link to comment Share on other sites More sharing options...
706 German Posted July 18, 2022 Share Posted July 18, 2022 I run all Mitas tires on my field tractors. Have Firestone radials on the yard and haying tractors they seem to last well. I will not run a 23 degree bar tire in the field on my ground all they do is ball up. The 30 degree Mitas tires clean out so much better in my conditions. Quote Link to comment Share on other sites More sharing options...
KyIH Posted July 23, 2022 Author Share Posted July 23, 2022 Well, I got some tires. I wasn’t able to get the firestones and avoided the malhotra as was suggested. I went with the Titans which look like good tires and are made in the USA. Hopefully they’ll last me a while. Thanks for all responses. 5 Quote Link to comment Share on other sites More sharing options...
Frank H Posted July 27, 2022 Share Posted July 27, 2022 I love new tires. 1 Quote Link to comment Share on other sites More sharing options...
db1486 Posted July 27, 2022 Share Posted July 27, 2022 Should last you a long time. I looked at them when we got tires this spring but went with a pair of Alliance since they were about 250 each cheaper. There's enough of those titan tires around here and they seem to hold up alright. Quote Link to comment Share on other sites More sharing options...
db1486 Posted July 27, 2022 Share Posted July 27, 2022 Double post Quote Link to comment Share on other sites More sharing options...
