dannyredfan Posted July 4, 2022 Share Posted July 4, 2022 Can you put hYTRAN in a newer 05 model jd. ? We got a water problem Quote Link to comment Share on other sites More sharing options...
Dirt_Floor_Poor Posted July 4, 2022 Share Posted July 4, 2022 I don’t see why you couldn’t. Quote Link to comment Share on other sites More sharing options...
nomorejohndeere Posted July 4, 2022 Share Posted July 4, 2022 Flush out water whatever you use.... Quote Link to comment Share on other sites More sharing options...
MarkG Posted July 5, 2022 Share Posted July 5, 2022 Not sure about the best fluid to use. We have a 5603. Do yourself a favor and remove the plug below the pto clutch. They plug it at the factory and the cavity will get water inside. The pto is a dry clutch and if water sits on it for an extended time it seizes up. You have to split the tractor to fix it. Quote Link to comment Share on other sites More sharing options...
dannyredfan Posted July 5, 2022 Author Share Posted July 5, 2022 Thanks for the reply’s I seem to remember people saying that you can’t put hYTRAN in the older deers because of the brakes. The water was added to it. They got a old bucket and wasn’t paying attention 😫 Quote Link to comment Share on other sites More sharing options...
bitty Posted July 5, 2022 Share Posted July 5, 2022 20 minutes ago, dannyredfan said: Thanks for the reply’s I seem to remember people saying that you can’t put hYTRAN in the older deers because of the brakes. The water was added to it. They got a old bucket and wasn’t paying attention 😫 I think the hytran/JD issues is that they use a water soluble adhesive for their friction plates in the transmission. Hytran will suspend the water and remove the friction from the steel backing 1 Quote Link to comment Share on other sites More sharing options...
dannyredfan Posted July 5, 2022 Author Share Posted July 5, 2022 Even worse I had just changed it the day before. It was a little over full and clear. Dad 85 year old, thought it was out. We flushed with new cheap oil and a gal of diesel. Then put new jd oil back in. But 3 weeks later it's acting up again 1 Quote Link to comment Share on other sites More sharing options...
