756puller Posted July 4, 2022 Share Posted July 4, 2022 What's the right way to check for bad shaker bushings? I was taught to look for them cracking and falling apart. Quote Link to comment Share on other sites More sharing options...
superih Posted July 4, 2022 Share Posted July 4, 2022 Check for the bolt not being centered in the bushing Quote Link to comment Share on other sites More sharing options...
brahamfireman Posted July 4, 2022 Share Posted July 4, 2022 14xx 16xx 21xx 23xx combine??m Rotate until shaker is in middle of stroke, put a pry bar under pivot arm and try to lift. If on shaker itself you can get pry bar in the slot and lift on shaker support. Any movement at all and your on burrowed time. Quote Link to comment Share on other sites More sharing options...
756puller Posted July 4, 2022 Author Share Posted July 4, 2022 Yes it's for 1400/1600/2100/2300/2500 series combines. When I was learning combines 15 years ago the head combine mechanic at the dealership I work at taught me to just check for missing rubber, rubber coming apart. All in all it's served me well. Quote Link to comment Share on other sites More sharing options...
wheatking Posted July 5, 2022 Share Posted July 5, 2022 i know a guy who fires the shaker system and watches and at slow rpm shaker speed carefully puts his finger on the bolt and feels if it slops from front to back as it moves said it works i've never tried it Quote Link to comment Share on other sites More sharing options...
